  • Replies 108
if only i had the time
i did the maths for the burnout donut record. and after some calculations, it's safe to assume that the rb30det donk in my 4door would be blown or very near blown once it got anywhere near that record.
bummer
time for a stocker.
this weekend im flat out doing my car!
jas, can you let me know where you got that info from
try this
that should send you to the program for power cruise.
6.00pm – 9.00pm  Hoosier Tyres Australia Twin Burnout Competition . One Shot Only.
Gary Myers vs Peter Gray.
Guiness World Record Donut Attempt during the Burnout Competition Finals. This is a one shot burnout competition. You will have a minimum time for a score of 1 minute. You can go for as long as you like. The winner will receive cash and prizes as listed in Prizes/Trophies. We will also be paying the top 10 burnouts so it won't matter if you come in 2nd or 10 th , you will still be in the money. Check out the burnout comp rules for further info on requirements and judging.
some prizes for the budding drifters out there
Prizes
EVO Motorsport has supplied a full X-Force exhaust system as well as 20% off gift vouchers (call Mike 62281222)
Gulf Western Oil “the tough Australian” is supplying some of their latest Sogi oil (call Darcy 0409315772)
Revolution race gear $50 gift voucher (call Brendan cook: 96484044)
Drift battle DVD’s
$2 dollar raffle joy ride
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
