Busselton
  • Replies 60
ur mates mates mate test drove the car and saw what he was getting when he handed it all over :)
the seat (single) and mags came off ages ago. well before ya mate had interest in the car. as for the CAI it was just some flex pipe, $10 from bunnings :)
trust me yer mate got a VERY good car which should have sold for a lot more then it did :)
https://www.sau.com.au/forums/topic/7964-busselton/page/2/#findComment-116910
I was cruising back from Margeret rvr just after x-mas and i waved to an R32... i got a thunder grey r33..
Also as i arrived in margs on x-mas morning there was a white r33 on the lawn of some house. at the bottem end of town. didn't see it again tho'.
i know whatyou mean about ppl down south noticing the skylines. heaps cool :D
https://www.sau.com.au/forums/topic/7964-busselton/page/2/#findComment-118423
Originally posted by Pva_Glue
4 skylines
2 silvia
2 180sx
2 EAX
around 20 -25 people...
cheers
Joe
Hey, did u forget about me in my abscence eh:(
that was a nice drive but i think it would be a little harsh driving to and from in the same day (6hrs on the open road) would be better to make a weekend of it again.
https://www.sau.com.au/forums/topic/7964-busselton/page/2/#findComment-119181
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
