As it says i got a custom box with 2 12in subs in it they are the MTX thunder series, they are pretty new about 6 months old and they are in a custom enclosure behind a perspex window angled outwards. im also throwing in a Avalanche amp thats currently powering them. the amp is also pretty new although it is dirty. it is the latest from the Avalanche series. Im after 300 for the lot and i need it gone asap.!!!
thanx
heres all the info boys
http://www.mtxaudio.com/caraudio/pr...roadThunder.cfm
__________________
https://www.sau.com.au/forums/topic/79688-fs-2x12in-mtx-subs-in-custom-box/
  • 3 weeks later...
thanx
__________________
PM !!!
very interested
Yer except i got em in a sealed box now boys. im after 250 so i been getting offers for ridiculous amount which im not gna reply to so if u want em come n get em
Hi,
Quite interested, but can you clarify the following:
- How big is the sealed box? Will it fit on R33 GTST?
- How many watt RMS is the Amp? How many channels is the amp? Is it bridgable? Also. is it powerful enough to power both subs?
- Can you provide pictures?
- Will you accept $220? I live in Rockdale, so payment / pickup should not be a problem
Thanks
DD
Edited by dd4321
Hi,
Thanks
DD
OK the box is currently in a r33 atm. It is a sealed box. The amp is running both subs now. The amp is a Avalanche 800w job so RMS i have no idea
I have no pictures and im willing to accept 240 for the lot
my contact number is 0414 069 629
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
