welcome man
treat her like u would ur gf:
trash the shit of teh beast!!!
na - only jokin man
if ur also interested www.r31skylineclub.com
good site
how many kay's on the clock
does she ave a good diff and gbox? - the most important things in a r31 (the engine can be thrashed to shit before it gives out so i wouldn't worry about that just yet - just watch out for a weak diff and gbox)
https://www.sau.com.au/forums/topic/79742-hello-everyone/#findComment-1452514
Thanks alot...Its good gear box and diff.....I got it for $500..Cause the owner was told by NRMA that the coil or distributor was hammered..But me and my dad tried 4 Coils and 2 dizzy7's yesterday and nothing..So i thought maybe it was the timing belt...So we unscrewed the bolts and sure enough the timing belt was in a million pieces..So a R31 Fpr $500 that only needs a $25 timing belt from repco :rofl:
https://www.sau.com.au/forums/topic/79742-hello-everyone/#findComment-1453033
  • 3 weeks later...
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
