I went backwards in the old skyline with ansafc but it imporved the fuel econ heaps and made for a smoother aplication of power.... Id recomend it if you dont want to go to a pfc...
Althought in saying that i reckon pfc set up properly will be better bang for your buck... and you motor will last longer tuned with a pfc properly...
There are many who say they can tune a safc but the reality is that if you get it wrong you will lean out and something will go bang.....
hey geno8r  :) wat other mods have u got on ur car ??
Performance Mods would include:
T3/T4 HighFlow'd VL Turbo
GTR FMIC
GTR Fuel Pump
S-AFCII 'Dyno Tuned'
GReddy Profec B Boost Controller
3" Exhaust Turbo Back 'inc. HighFlow Cat
K & N Pod Filter
Irodium Spark Plugs
Blitz Open-Atmos BOV 'not exactly performance, but helps keep turbo flow'in
Brass Button Clutch
Always run BP Ultimate
Stock RB25DET engine.
Stock Headgasket, Injectors, Cams etc.
Thats about the gist of it...
Here's a good dyno sheet showing my first performance tune with the SAFC
The lowest line is approx 230 rwhp with the SAFC running stock A/Fs ‘eg no tune’
The next line up approx 255 rwhp was after the SAFC tune ‘still running stock 7psi’. The top line 292 rwhp was when running 12psi on inferior fuel. Since then using ultimate & a leaner tune have now got 309 rwhp on 12psi.
EDIT: You didnt have to delete your post but I've answer your question anyway.
justin911 asked "is wizzles killowatts or hp"
Wizzles as in Kilowizzles...KiloWatts
If it was Hp I spose I would of said Hisopizzles
lol Gizoogle has really influenced me lately www.gizoogle.com
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
