Ok recently i was pulled over and fined for not indicating x 2. i dont have enough points left to take this lightly.
Here's what happened....
I was in right lane.
Van infront of me decides to do u turn at specific "NO U-TURN" sign, indicate at the last minute and leave their ass hanging out in the lane.
To avoid braking heavily and possibly receiving a rear end hit i checked the lane beside me, it was clear so i changed lanes, went around the van and back into the right lane...weeoooh cops pull me over.
I explained the situation, still got the fine and if it weren't for my permits, i woulda got a yellow as well.
I dont even remember if i indicated or not, the fact is it was a last minute decision because of the sudden change in what was a smooth continous traffic flow.
Anyone been through something similar? Is there a way to settle it out of court?
it was your fault , you were following to close . you should always leave enough distance behind the front car to stop if there is sudden braking . Swerving and changing lanes is a never a good idea , lots of people swerve into an opposite oncoming lane and have a head on collision.
youve got to break in your lane in time to not hit the car infront , same for the people behind you . If not you were following to close .
you have no chance of fighting it and winning . the out of court settlement is to pay the fine .
You may be able to get it lessened, theres no harm in trying. Write them a letter explaining the situation (if u have a clean record even better) just be polite but formal in your letter and hope for the best. Its worked a couple of times in the past for mates of mine and i myself have gotten away from a fine by explaining the situation.
Its not worth Fighting it, I'd say based on the above comment her record is not "clean"
Simple fact is if you needed to swerve to avoide the traffic in front you were following to closely. Chances are you got off lighly with a charge for no indication. You could have been charged with careless driving or worse
One of the few remaining benefits of being in Australia is that you have the right to take this to court if you want to.
They cannot give you a greater penalty - only what you have been charged with plus court costs. If you do elect to take it to court, you have the right to request the officer's statement that will be presented. Make sure that you do this as the version presented is often very different from your recollection (or reality?).
Good luck.
In addition, in order to preserve you license, you can advise that you will be contesting the matter, and by the time you get a summons you should have (hopefully) points back so you can pay the fine and any admin fee and still have a license.
At any time before you actually appear in court you can pay the fine and the matter is finished.
It is no substitute for good driving, but simply a means to keep your license and learn to keep it clean.
Edit: your points are not deducted until you pay the fine.
her32 it is worth a try to write them a letter, just explain the situation, its not gauranteed to get you out of it but its worth a try. simply writing them may save u a bit of money, and if it doesnt work there was no harm in trying
There was at least a 3 car space between my car and the van infront if me.
This road is not safe for u turns, hence the sign that says "no u-turn"...
it doesnt matter if theres a 50 car space , if you cant stop in time and have to swerve into another lane , your to close your at fault .
It doesnt matter if they guy decides to just stop in the middle of the road for no reason , if you hit im from behind or commit an offence to avoid hitting him from behind its your fault .
Sorry im just telling what is in the road code .
Have to agree with the others, if you had enough time to brake, or do as you did & check your blind spot, you had enough time to indicate. Try your best as far as you want to go, but I don't fancy your chances. They will also take into account the fact you already have a decent amount of points against you.
Let us know what happens anyway, good luck with it.
don't bother trying to fight it, i lost my license 2 weeks ago (not for anything stupid i might add just accumulation of 12 one pointers........) just take what you have been given, if it makes you lose your license so be it...... trust me I couldn't afford to lose my license either as I have work,studies and other commitments but hey shit happens and I did....... Don't bother applying for E plates if you only get a 3 month ban either as by the time you get to court to explain why you should be given the E plates the three months would have been up already :) Enjoy transperth as it's my New Best Friend too :rant:
I've argued the point. Never won but, always worth arguing a point when your about to lose your license for points.
Then by the time you actually have to pay the fine you get enough points back :)
My longest time to postpone a fine was 18months and coming in a close second was 13 months :)
Good luck :)
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
