I had 3" Exhaust done from the turbo back as in the sig below.
Does this dump pipe look like they have used a little to much pipe then brought it back on its self in turn creating a V right in front of the exhaust wheel?
Hence possibly causing more of a restriction than the stock dump pipe?
It is a real noticeable V when you run your finger a long it. There are also lots of blobs of welding slags.
So what do you think ppls should I see if they will fix it up?
On their show floor they had a dump pipe sitting there that was extremly well made, that they made.
No obstructions in air flow and a very smooth finish. No V's!
I'm asking you blokes first as I paid $1750 for this exhaust.
I would be jumping up and down why didn't you get a jap one you could of had and brand new jap one for that money. and peopel say use the local product when it comes to exhaust the japs make the best and gues what they fit in 10 mins and never rattle or groan
meggala
fark my rb25 turbo is on full boost by then and the exhaust wheel is heaps bigger did you check you turbo when you pulled it off the exhaust wheel should be quite a bit smaller than the vg 30 turbo.
where as the rb 25 one would only be slightly smaller 1mm
cheers
Joel,
If you paid that sort of money then I would expect a much better job than you have recieved. I had a full system put on including dump pipe with separate wastegate pipe, hiflow cat and stainless 3" muffler for just over $1000. Just go back and say that you do not think that the exhaust is very good and whether they wouldn't mind fixing it.
It always pays to be nice at the start, then if they prove to be wankers then you can start ranting and raving. All the exhaust should be mandrel bent, and you should have no restrictions in the 3" exhaust.
Good luck.
See'ya:burnout:
The Exhaust i wanted was a 3" From the turbo back in Marine Grade stainless steel. It also is Mandrel Bent.
What exactly is Mandrel. Is it supposed to have quite a few welds. Like bits of pipe welded everywhere.
Just in the dump pipe its self I've got like 4 or 5 welds going to the cat.
why stainless joel do you plan on keeping the car for 10 years +
yes mandrel bends mean the same internal diameter and yes quite often there are some cut when it is doen by some one with out and proper template like hks or apexi or trust..
meggala
look at the design of my n1 I got it second ahand see how the thing flows so well and I have no dump or front pipe.
the old one is at the rear the new one is at the front
I am an idiot. I realised after I got the thing.. :P
They also apparently resonate more.
I was looking at the stock VG30 Dump pipe and it actually looks very well flowing appart from the Wastegate that has very little room to flow and you can see how it would create a bit of turbulence when it opens.
Joel/Meggala,
I thought mandrel bending involved using a block inside the pipe so that as the pipe is bent then it keeps the bend at a perfect diameter with no folding where the bend takes place. I don't see why there should be any welds whatsoever, except where they join flanges together, an these welds should be ground back both on the inside and outside.
Joel, don't be too hard on yourself, we've all made mistakes with our cars, but if your not happy with the workmanship then let them know they might be willing to fix it.
See'ya:burnout:
That 'V' is at the mouth of the turbine not the wastegate right?
If so, that isn't real good for your top end power and might slow spooling down a tad.
If they advertise a dump pipe (showroom style) and you say "I want that one" thats what they should give you. Be diplomatic about it and they might just fix it free of charge.
Don't go doing the sepparate wastegate pipe if you redo it they are not as fab as some make out and can cause further problems.
Joel do you mean there is welds by each of the bends, ie in front and behind a bend they may have used bends and welded them together to make the exhause. That is what i do. If you didnt live so far away id have a look, my exhaust full cost me under 300 to make full turbo back with satinless can, i dont have a cat on at the moment.
If you are worried about the dump pipe get the die grinder out and clean it up a little.
It looks like they have used to much pipe and it steps up say 10mm past the bottom of the flange then they have used a small piece of pipe and welded it in angled down to meet the bottom of the flange.
The resonator dosent look like stailnless thats why there is the black paint there hard to tell though.
I wouldnt worry too much about the dump pipe, there would be very little restriction and it would be better than the stock one.
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
