Sorry if there has been a thread on how to install this on an R33 already..
but I can't find it anywhere.
I got a Tomei Hicas Lock in the post today and all the instructions are in Japanese, unfortunately I don't read Japanese either..
Has anyone installed or knows how to install one of these kits in an R33?
Do you have to enter HICAS Diagnostics mode to install the brass bushes?
and how do you know which wires to splice into to install the little black box thingo?
Any help would be much appreciated thank you.
https://www.sau.com.au/forums/topic/80163-tomei-hicas-lock/
The pics are in the file, but somehow not showing. I think it's still pointing towards the site that used to host the file which is no longer up.
I tried to fix it without success. I suck at Word, Excel, etc...
Try this link for the zip file and see if you can fix it.
https://www.sau.com.au/forums/topic/80163-tomei-hicas-lock/#findComment-1463740
Thanks, enough there for me to work with.
Cheers :)
https://www.sau.com.au/forums/topic/80163-tomei-hicas-lock/#findComment-1464024
You can get it from Greenline or Nengun etc... They are around $150.
For a street car you wouldn't really bother to cancel the Hicas. On track cars it's a worthwhile mod as without Hicas you get more predictable behaviour.
I still haven't fitted mine, but AFAIK it's not better or worse than the lock bar.
It's just a pair of oversize washers locking the rear steering arms in place so there is no movement. Hence easier to return your car back to stock if you wanted to.
https://www.sau.com.au/forums/topic/80163-tomei-hicas-lock/#findComment-1464429
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
