I'm currently looking into 100gig/month hosting based in the US for ~$15/mnth.
If I do this however I may/may not front the whole cost.. with 100gig I can also host alot more files/videos as i'll have 5x bandwidth. i'll get in contact with some admin's and have a chat.
just giving ppl an update + wanted to get some feedback as to whether they would like this to happen?
update: currently in discussions with my current hosting - so we'll see what he says and I might be up and running again soon..
  • Replies 105
Hey all,
FYI this has also been mirrored here:
http://bur.st/~rinmak/sau/
User: sau
Pass: skyline
Much faster than the technine.org mirror and I would prefer if you chose either this or Links' mirror from now on :)
MODERATORS: This really should be a sticky or under the how-to's or something. Its a very good resource.
Also, I will get around to bringing some of the newer stuff over to these other mirrors when im not so lazy :)
i have and r31 service manual, australian models and gregories trans and drivetrain avalible for upload also for aus models eg rb30
all i need is gregories engine section, i dont even need the others
il willing to upload them, pm me a ftp where i can send them all and i will
+someone please get me the gregories aus r31 engine one
Thanks to V-Spec we've now got the Gregories Diff and Trans books up on the server as well as the R31 Service Manual..
http://www.crankroom.com/sau/R31/
Check the first page for username and password..
Does anyone have a copy of the R33 SII Owners manual
There is one in english that I am after, it's bloody impossible to find.. Cheers guys..
:( Thanks for some info on R32, However not able to download R32 all engine man
when I click on it it says Done but the page is blank? Do you know what I'm douing wrong? :P
Donutdave - i've tried them out both work downloading and viewing on the site (i'd recommend downloading them..)
Make sure you have Adobe Acrobat 7.0 installed - you can get it on the front page, i'm pretty sure the R32 all engine manual requires it.
You are right with Adobe I had 6.0 version, However when I went to download it from the front page at the end of download I get error "file corupted" so it's not working for me. I'll get 7.0 somewhere else first.
Thanks anyway :P
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
