Again, did not receive anything today.
This is really not looking good.
I posted it on tuesday and it should only take 3 working days.
Did you check at your post office?
Cheers.
  • Replies 72
i have purchased from gR33ddy before and had no dramas, im sure there is only a mix up, if anything....
Thanks mate.
There hasnt been any mix-up its just the wait for delivery from NSW to QLD. Can take from 3-5 days.
The item should arive monday.
Thanks mate.
Should arrive monday? You said in the PM it should arrive Thursday/Friday.
Box of lanyards arrived this morning which was sent through Australia post. This box was sent on Friday.
This goes to then tell me that either the fmic & kit hasnt been sent or is somewhere in transit and Australia Post are lazy and wont delivery it. As the sender, you can follow through on where its at and whats going on with it. I cant as I didnt send it off.
Can you please follow it up?
I tried to send you a PM but your inbox is full.
Edited by r33skyliner
Went to my local post office here in the city (the GPO) and they've not received any packages with my name on it. They've also contacted another post office here in the CBD and they've also not received any packages with my name on it.
They've told me that you need to submit a 'Enquiry' form for it to be chased up and followed through as to where it is.
I would PM you about this but your inbox is full.
I originally thought it would arrive on time. I was confident that it would. That is why I said so.
I dont spin BS just to make a sale.
I have no explanation for why your item has not arrived yet??
I will fill in the enquiry form at the PO but as you are probably well aware, this can take a number of weeks to process and Aus post will most likely do nothing to locate your parcel.
In the meantime I suggest you keep checking at your PO and your work addy that it was sent to.
If I could do any more then I would.
I trust the Lanyards are genuine??
I sell NISMO products and I have never seen NISMO lanyards.
My Japanese distributor is keen to check it out.
We recently exposed some fake ones being sold on ebay.
The ones that I've brought from a distributor, I have been told are genuine.
If I really wanted to sell fake ones, I could of gone and had some made myself and sold them cheaper.
As for the FMIC. If it does not arrive tomorrow. Then your able to submit a form to Aust. Post requesting for them to re-inburst you for the amount that the product and postage (that being a total of $630) back to you. Once you've received the money, you can then pay that back to me. Aust. Post usually takes 1-2wks turn around to refund the money.
I planned on having this FMIC by the wknd just gone so it could of been installed on Saturday just gone. That now being the case that it didnt arrive. I've had to now push it back to this weekend. If it doesnt arrive this wk. Trust me, some fist are going to go flying at the GPO here in Brisbane.
I'm not paying nor loosing out on $630 cause some theiving asshole at Aust. Post wants to steal my FMIC or cant be f**ked properly sending it through so it gets delivered to here.
And if you think I'm not angry. Trust me. I'm more then humming about this.
Your intercooler kit has been returned because you gave me the wrong address.
Please send me the correct address.
PM sent.
PM sent.
The address Paul wrote on package had a "-" instead "," which is where Australia Post got confused on where to send it.
The proper address has been given to Paul again & should arrive without any problems this time.
I'm a bit more releaved now that I know where it is (though I rather it be in my hands right now then back at it's senders destination) and Paul is now re-sending it to me today/this morning by express postage. Should arrive here tomorrow as Express Postage is 'Next Day Delivery'.
Once it arrives. I'll let you's all know.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
