  • Replies 61
Here is what's in stock or landing soon
Algernon Intelesse
17x8.5 +15
17x10 +22
114.3 5hole
Intensive Hunk
19x10.5 +-0 front
19x12 +-0 rears
brand new rubber on the rears. the fronts are 95% as new.
114.3 5hole
an example of the VSKF wheels we have on their way. landing soon.
18x8.5 +40 (big caliper clearance)
18x9.5 +43
114.3 5hole
HKS Hiper Damper to suit S14/S15 SOLD
8kg front springs, 6kg rears
height and damper adjustable
Work CR Kai
18x8.5 +37
18x9.5 +37
114.3 5hole landing soon
More to come in the coming days and weeks.........
something for the S13 owners. :(
Cusco's
height and damper adjustable.
7kg front springs and 5kg rears.
low k's. no leaks or defects.
$1199 sydney pick up. interstate delivery also possible.
these will be here late August
how much for them SSR professors?
Say, 17x7.5 and 17x9's, if not then 18's with the same width? If you were to get another set or two, or three or four
Coilovers for HCR32 don't come with camber tops. Only BNR32 (GT-R)
I can find you many sets of coilovers ranging from Cusco to HKS to TEIN.
I'll PM you with results over the weekend.
Cheers.
Charles.
R34,
if we take a popular size that fits a 5 stud silvia or a rear wheel skyline, the typical sizes that fit under the standard guards is
8.5 +35 fronts
9.5 +35 rears.
with this in mind,
these Hunk Intensives' do have very similar clearances on the insides as far as strut and inner guard clearances are concerned. the main differences is that they need 50mm to 60mm guards front and rear in order to fit.
they do have 60mm extra dish on the fronts and 65mm extra dish on the rears.
the tyres are a smaller tyre that is stretched to fit on the rim, giving a better chance to fit under the 50mm guards.
Hey would you be getting anymore VR GT-C's in?
im after 18's or 19's to fit R34.
Whats the price on a set of those?
Im after Gold though but any color will do.
Cheers mate!
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
