  • Replies 41
Dont forget however that 200rwkw in an s15 6 speed feels a shitload faster than in an r33!
If your thinking about one and dont need the extra space of the Skyline id definatly go for it! Aslong as its not an s14, s14a and s15s are the better looking cars.
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1467304
I'd put it in the 180rwkW region with those mods, at around 1bar.
The injectors and pump won't be maxed out, but they'll be close. For safety's sake you'd get a new pump and injectors before trying to screw out any more power.
The T28 will clear 200rwkW with cams.
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1468623
Aussie S15 T28's all ball bearing? This means with support mods they can hold say 17 psi safely?
I thought the JDM s15s were the ball bearing ones. Like the spec Rs or something. Have a look a nissan silvia they have a heap of dyno threads.
About your question i reckon what everyone else has said around 180- 200rwkw.
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1468695
No, they're not.
I believe the consensus is that the JDM S15s are all BB, but its pot luck as to whether the Australian ones are or not. Silvia owners have compared build dates, VIN numbers, part numbers for the turbo, and there's nothing they can see that differentiates between them.
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1470653
Exhaust housings... as im on NS.com all the time this is where i got that from.
B/B units have a 6 bolt exhaust housing while the non b/b turbos have 4? Maybe 5.
Not 100% sure on the non b/b units but they dont have as many bolts in the exhaust housings, this as well as a slight difference in the part number does show Aus Spec s15s have non b/b units!
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1470660
Well yes, if you look at them you can tell the difference.
But if you're in the market for buying one you won't be able to tell from the build date or VIN number.
From the people I've spoken to on SilNSW and NSCC the part numbers for Au S15 BB and non BB T28s are identical (hence why a VIN number search is fruitless).
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1470691
first of all - which 200sx you talking about?
those mods on an S14 or S14A will get about 180rwkw.
same mods on the S15's tend to get closer to 190rwkw.
my series 1 S14 with 1 bar boost, fmic, SAFC pulled 175rwkw.
ran a lazy 13.8 with heavy 17 inch wheels.
A mate with an S15 and 193rwkw using PFC and 17 psi ran 12.9 on the same night.
on the topic of BB turbo's and shit.
it doesn't mean anything for it to be AUS or JAP spec.
some had Ball Bearing and some didn't.
only way to tell is from the GARRETT part numbers on the stamp which is on a plate on the turbo between the front and rear wheels.
466541 = ball bearing
466543 = bush bearing
the second part of the numbers mean
-001 = S14 turbo (no splitter between wastegate and turbine exit)
-002 = S15 turbo (splitter between wastegate and turbine exit)
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1470738
Scathing -
yeh that would be Brentons right?
I think he had in the region of 225 rwkw with a lot of other mods apart from the turbo.
the original question was using "highish boost"
which doesn't mean much really.
So to "me", the stock setup runing 7psi of boost, "highish" would be double and a little more..
so I'd say that 17psi is highish for a stock turbo.
The example I gave of my mate that ran the 12.9 was using 17.5 psi boost on his stock S15 turbo.
Scathing, if you are the same scathing on other forums, then you'll know Dale.
and I think that night you were hitting 14 flat in the tree fiddy... if that is you..
his other mods at the time were.
stock dump, then 3 inch back.
hyperflow intercooler with silicon hosing.
AVCR
GFB hybrid bov
17x7.5 rims with Dunlop DJ-01's
Power FC
stock clutch
stock pump
stock injectors
stock fuel pressure.
stock turbo... etc
I don't think the difference between the BB and non BB is not so much power but the driveability.
I would "ASSUME" that the BB turbo would build boost at a faster rate.
I guess they have other bonuses like higher tolerances to extra boost maybe but I can't say from experience.
https://www.sau.com.au/forums/topic/80647-200sx-question/#findComment-1472208
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
