Ok... After a year of owning the car with no problems whatsoever...i have finally came across one.
Problem that i'm having is -- the battery seems to be draining heaps quickly.
i have not driven my line for 5 days... so i assumed due to the cold weather..of course we get that awful cold start..i tried starting my car-- no luck.. till it just pretty much drained the battery. ( u get that "click click click " noise everytime u turn ignition on )
so i assumed battery was dead..i had it jump started and it went ok..started.. took for a 30min drive around town.. went to the supermarket for an hour.. when i got back.. the darn thing wont kick in.-- dead battery AGAIN.. so i jump started and worked OK. -- this i assumed the battery needs replacing as i had it ever since i bought it.--- so i got me a new one.. one click and the car started.. no problem. -- now went home and tried starting the car -- 4 tries and NO LUCK.. kept trying till i hear that " click click click " noise -- battery dead again.
i dont get it.. its fine when i jump start it.. starts pretty easy... but when i leave the car off for just 2 hours..it wont start.
I ruled out the alternator coz i had that problem with my previous car and the symptoms are not the same.. the car runs well..using aircon on / stereo and head lights.. nothing i know of that signs of alternator problem.
could it be the starter motor ? :confused:
Anyone who had the same problem and would be of help would be appreciated
thanks.
https://www.sau.com.au/forums/topic/80824-rb25det-power-drains-help/
If you've got a multimeter, put it in series with one of the battery leads and measure the current draw with key OFF. Should be close to 0. Anything more than 1/2 to 1.0 Amp will drain the battery pretty quick.
Is the battery voltage around 14v with the engine running?
If it jump starts OK, i'd doubt it will be the starter. Sound more like a lack of voltage problem.
hey does it just click or does it crank really slow??
plus double check the starter & battery terminals also you may have a volt drop on the switch wire to the starter
when you mean its flat are you sure its flat like are you head lights dim??
will your radio work??
if they do well could possible be starter related
just went and check the boot light and it was fine.. doesn't stay on.-- all terminals are fine.
and yes.. i can still play the radio / stereo and some lights.. but it just wont crank up.. and when it does.. it is slow.
could be a voltage drop.. dont think its the starter as it fire up fine when hooked up to another batery.
now.. how to fix this voltage drop..??
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
