I didnt like the idea at first as my brother changed them for me too see how they look and geez they look bloddy great. Photos dont do it justice. They are exactly the right offest. They fill out the gaurds perfectly.
Oh well, I like to do things that are a little different and if it means putting falcon rims on so be it.
https://www.sau.com.au/forums/topic/8085-my-new-mags/#findComment-117630
Unfortunately it has the tickford eagle in the centre cap. Might see if I can change it some how.
First time I put them on today and have scratched them already and they were in perfect condition.
I do have a set of awesome work equip 17's but unfortunately they are to wide.
https://www.sau.com.au/forums/topic/8085-my-new-mags/#findComment-117639
Guest Boxhead
Originally posted by Sumo
Can you put commo rims on a skyline? I have a set of 17's off a commo I would like to put on my R33, but wasn't sure whether they would fit?
Cheers
Sumo
i hightly doubt it as there diff stud patterns, and ppl are sayin use spacers, i thought they could only be used if the offset is wrong.. i dunno.. have a look at this link:
http://forums.skylinesaustralia.com/showth...=&threadid=8102
https://www.sau.com.au/forums/topic/8085-my-new-mags/#findComment-118297
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
