its nearly time to start modding the 33 so i thought id see if anyone could help me achieve the best results
im gonna be fitting a 3" exhaust from turbo back so i need ideas on places that do good exhaust fittings. im also interested in keeping it quiet to attract less attention without loosing any power (if possible)
i got a cooler goin on which is all sorted
and a safc2 which i will prolly leave in the glove box for the time being. ill probably get it tuned at chiptorque...
if anything else can be done to make more with stnd turbo and safc (like fuel pump. or reg or something) please tell
also, anyone got any experience installing a new stereo themselves using stnd speakers?
thanks for your time
https://www.sau.com.au/forums/topic/81162-plans/
As to the Exhaust, Rob Bliss did my dump pipe and I bought a aftermarket exhaust from japan that was 3" stainless and pretty much a straight system including 3" cat. Some really good prices landed are on offer if you are prepared to look and wait.
Dave
https://www.sau.com.au/forums/topic/81162-plans/#findComment-1474967
i got my dump pipe through batmbl here on the forums
was excellent
chased up a secondhand gtr cooler cheap, which meant i could spend a bit more on converting the plennum to forward facing (less piping, less hassles)
got a good quiet blitz exhaust for less than 500 bux from option1 (they had plenty to choose from)
https://www.sau.com.au/forums/topic/81162-plans/#findComment-1475126
Where you going to drive it mostly? Going to do any track or mountain work?
Sounds like you have the basics covered.. and should give you around 170-200rwkw with stock turbo. After that I would look at spending money on suspension, sway bars and other handling items before going too much faster as you'll be losing it to the ground. Sort them out and you can beat many other cars which much more power :)
https://www.sau.com.au/forums/topic/81162-plans/#findComment-1475145
I Installed my own sterio I was thinking about using the stock speakers. However mine were buggered. The cones are paper and are either dead or about to be dead. I hooked my head unit up to the stock speakers and it sounded awful. Went to JB and got two sets of Pioneer 6' two ways for $98. Now it sounds 100% better with out costing too much. Ditch the stock speakers and look for some bargins on good brand speakers :uh-huh:
https://www.sau.com.au/forums/topic/81162-plans/#findComment-1476226
Got in touch with vic member INASNT he can supply whiteline for cheaper than thier website.
Got to consider sizes now, thier upgrade is 24mm front & 20 rear but they also have 27F & 22R, he can supply the 27f but only 20r.
Is it worth putting that combo on or would it affect the dynamics as it is the rear I want to tame?
:confused:
Diam
Refers to the diameter in millimeters of the Whiteline/Selbys Swaybar catalogued bar. Generally these are "touring sizes" with replacements being around 1-5mmlarger than the original. Note that "extra heavy duty" oversize diameters are also available for many applications. Some Whiteline/Selbys Swaybars are of the same diameter as original, but only when replacing an OEMhollow or tubular design with a solid Whiteline/Selbys Swaybar.
https://www.sau.com.au/forums/topic/81162-plans/#findComment-1478779
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
