http://www.tempetyres.com.au
Has anybody dealt with them before or know of anyone who has? They look pretty well organised. I am thinking about buying some 17in nankangs from them $120ea + $10 freight. My main concern is their delivery, as I need them within the next week or so...
Any recommendations would be tops.
Cheers
Cal.
https://www.sau.com.au/forums/topic/81183-tempe-tyres-sydney/
Dealt with them also about 8 months ago. They were good to deal with had the wheels sent to Sunshine Coast and had them in 4 days. Good prices too for wheel and tyre packages! Just make sure you confirm everything before they ship.
Good luck with the new tyres
  • 3 weeks later...
they are good...i bought a set of rims off them when i used to live in sydney...stay clear of ozzytyres- they are the worst, and big 0 tyres are just as bad
Totally agree Ozzy tyres are knobheads. I went there to get new springs in because the previous owner had chopped them and I got defected for it. I told them that I had to clear a defect, drove from Newcastle to Sydney, buggered around all day getting them fitted, got back home, went to a workshop to get it cleared and I was still 2cm under height. Ended up buying 12 rubber blocks, jacking up the car and jamming three in each spring coil, drove VERY carefully back to the workshop, got it cleared and sold the car 3 weeks later. Everything was falling apart from having such a harsh ride for so long.
Long story short dont go to Ozzy ;)
Long story short dont go to Ozzy  :angry:
You, might be the Knobhead,selling your car to some poor unsuspecting person knowing quite well it wasn't roadworthy.
Just my opinion though.
yeah a mate of mine has bought 2 sets of tyres off them, 1 set of 20" rims and a set of 18" rims all came within a few days and no problems with them. just make sure if you need offset or anything you state the correct offset to them and spacer size also. these are the most important things.
Um no actually if you read it properly i got the springs fixed, and the problems i had i only found out about every time i got a service. And she got an NRMA inspection before she bought a car. And i took the rubbers out. And dont say its unroadworthy because of the height, how many cars sell while being too low?
  • 4 weeks later...
I have a set of 255 nankangs on the rear of my 33....
They are falling apart.... Way toooooooo soft.....
There is rubber all up the back of my car all the time.... No burnouts either.... They are really tight but very fast wearing tyres....
At the price i cant think of a better tyre tho.... For price/km's traveled i think there pretty good.... Just hate the rubber all over the car...
i need sum 255 tyres soon aswell for the rear. i also have nankang ns II but i have them on the front. they are a soft tyre but they seem to grip ok but im going to get a tyre that is a bit harder compound for the rears bcoz i just dont think they nankangs will hold up to the rear end torcher. there just too soft.
Try falken azenis. I got 265/35/18's and they seem to be holding up good.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
