Sorry dont mean to be rude:
NA cars run with neg pressure in the plenum. This is what pulls a BOV open, therefore the BOV on a na car would be always open... This would be like punching a hole in your intake piping somewhere which would probably mess with your Air/fuel ratio's.
No performance gains to be made with this mod.
I am not 100% on the: "the BOV on a na car would be always open" call but i am pretty sure ;)
https://www.sau.com.au/forums/topic/81263-bov/#findComment-1476307
not quite right. the difference in pressure between the two side of the diaphragm or piston is what pushes the valve open. on the one side you have the boost in the intercooler pipe, on the other side you have the pressure from the manifold (post throttle) when you close the throttle pressure in the manifold drops but the pressure in the pipework is still high, the difference in pressure is great enough that boos pressure in the pipes is able to overcome the pressure of the spring.
https://www.sau.com.au/forums/topic/81263-bov/#findComment-1476456
cheers, that was kinda what I figured...
https://www.sau.com.au/forums/topic/81263-bov/#findComment-1476503
I seen the thread name "B.o.v" in the NA!!! Section of the site & just had to look & hope somebody wasn’t asking how to fit one or asking if it provides any performance gains... and...
Would fitting a blow-off valve to a non-turbo skyline provide an benefits to the performance at all?
Plus would the car build up enough pressure to produce any decent sound?
;)!! Hahahaha
Think your gona need a turbo m8 if you want to run a BOV.
https://www.sau.com.au/forums/topic/81263-bov/#findComment-1476556
Pardon the ignorance here... I have a turbo car which has the factory BOV on it atm...
Can someone please explain the imporatance of an aftermarket BOV? What are the gains to be achieved? And is it really necessary (being illegal and all)?
Thank you
Stan
https://www.sau.com.au/forums/topic/81263-bov/#findComment-1476632
Thank you
Stan
Aftermarket BOVs actually increase boost & raise torque... :D
hahah Nar aftermarket BOV are usually only bought because of the noise they make but they can also serve the purpose of venting a greater amount of air to keep ur turbo spinning better if you’re running higher boost. But there's always rally style anti lag systems which work better than that in conjunction with a BOV hehehe. BANG BANG POP
https://www.sau.com.au/forums/topic/81263-bov/#findComment-1476691
For your car & many of our cars, you'd really only get one for the noise / visual appearance in engine bay... Otherwise stocky is fine.
Thanks guys
Hey geno8r, when we going for that cruise? Or even just a general meet up?
https://www.sau.com.au/forums/topic/81263-bov/#findComment-1476773
Thanks guys
Ahh man I forgot about that... I got busy again... had some extra work coming in so been occupied... If someone organises sometime I'll be there but yeah just haven’t had time to organise anything really... If you reply to this probably best not to ‘off topic’ anymore in this thread & reply back in the other one...
https://www.sau.com.au/forums/topic/81263-bov/#findComment-1476781
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
