hey ppl im new on this but i would like to ask any in the A.C.T if they had a 4 door skyline and if they would be able to do some formal work , its easy cash just for 1 hour or so of your time , by the way its the lake tuggerz formal on the 6th of december . if any does could they reply to this post thanks .
and andrew thats the most ive ever seen you post in one week! i say just get 2 diff cars (if its for 2 couples) if its just on couple then one car i say, everyone on here has a hot line (except that leigh fella i wouldnt be caught dead in his JOKES leigh you know i love ya :aroused: lol!) but yeh if your after any line im sure atleast a couple of people may be able to help out
SAU have done heaps of formals like was said before ^^^ we have done convoys with about 15 skylines good fun one hell of an entrence and there hasnt really been any probs with dress'
but chicks have the finel say.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
