Hey all,
Was in the city last night, and we stopped by a game place to play initial D arcade game. Anyway, where can i buy those save card thingos? It said to put $2 in the machine to buy one, but i couldnt find where the **** it would spit one out? I figured it would chew my money so i didnt do it :(
So where do i buy????? :)
I'm addicted :D
https://www.sau.com.au/forums/topic/8172-initial-d-save-cards/
havent played in a while
from memory
it will tell you to put more money in to get a card, then when you finish Press View Change button and it will spit out
sometimes you have to put more money in
and i think when its game over the card spits out, cause it prints your name and your car and character and shit
Originally posted by Duncan
And, are they waterproof, mine had a swim in the washing machine tonight
I think so, only thing I see destroying one of em is by bending it or run a magnet through em.
On the back of the card it says
"If you bend or soil this card, the card reader may not be able to read your data."
Guest DFLASH
for PS2 fans... Initial D Arcade stage is in development for PS2... it's due to be released around May 03 in Japan... but would probably be real hard to get a hold of... I assume they will release an English version so it may even make it to Australian shelves.. fingers crossed
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
