Hi guys,
i am about to consider 2 different skylines up for sale now.
1. 1996 GTST S2 80,000kms
- Almost stock except for : Pod filter , new sony stereo with pioneer speakers, 16" wheels, clean interior, with rego
2. 1997 GTST S2 97,000kms
with mods like : Pod filter, forward strut brace, 17" rims with Bridgestones tyres, Rusty rotors, kenwood stereo, 3" cat back, turbo timer, only changed the timing belt, no rego
The 1997 model is about $1000 more expensive than the 96 model.
Guys, which one do you think will be a better buy? i am sure more people will be attracted to the 1997 model since it's a later year??
https://www.sau.com.au/forums/topic/81960-buying-an-r33-gtst-s2/
go off condition not off the km's/year model. Their is only one year in build date difference so i wouldnt worry to much about that, they are both S2's.
check carpets, wear on steering wheel and hand break. also get it checked out properly by a mechanic
Not entirely true. Who knows with half the cars that get sold they would have mods done to them and people return them back to stock. you would never know if done properly. Id disregard the k's year and mods and go for the one thats in the best nick. Get a compression and leak down test done on the motor and go from there.
guys what's a compression test and leak down test??? Where can i get it and how much will that cost me? I decided to go for the 96 skyline as it is in real good condition inside out..comes with brand new pioneer speakers..the owner is a great guy anyway...very honest guy and i should say he is pretty trustworthy...Guys how much do you think the 96 skyline will cost...it's stock as...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
