Oh you not takin the dyslexic one? lolz
umm..
SHWOFF - show off
CUSTMD - customed
CUSTRD - custard?
PPLATES - pink plates? .. some mite think its retarded coz it says "p plates" but anyway
32PLATE - 32 number plate
32PLAIT - 32 plait... and i think a synonym for "platt" ?
dno..
  • Replies 41
id go wid funkymonkeys NOBALLS... for the not so obvious reasons...
and i think SKYGRL works at safeway springvale... or used to newaiz (not shure)
not so obvious reasons?
blah cant do nothing about SKYGRL unless she sells them! put a note on her windscreen that when she wants to sell, i'll buy!
OTOME or SHOUJO = young girl
KANOJO = sweetheart
GEISHA
Better yet:
JO BAN = leader of a group of delinquent girls.
I saw a movie about that once...
:D
I like the jap ones... could look into them, my parents would be happy, havent used japanese since they spent the money sending me over there lol
thanks guys for all the suggestions keep em coming!
Yer some b*tch wont give up LILONE will she?!
LOZBEH lol omggg is that going to sick with me forever?
yeah nah she wont give em up....i even offered to buy it back!! but alas! Yes...Loz Beh forever!
  • 3 weeks later...
i think SKYGRL is this indian girl, (not a racist remark) I saw her in a white skyline S1...parked in Clayton just outside the Macs....I thought it was some babe untl she came out then..ermm....hmmm....
hehe actually as of today I have SKYGRL!
It will be on black 32 in couple weeks :(
Thanks for all suggestions, I checked some of them, but quite a lot were already taken.
Cheers,
Loz
Cheers,
Loz
she is a maniac driver so if you see her....avoid getting near her car! HAHA i have witnessed her driving!
maniac...? wat the!
sorry was I the one launching at the lights?!
I forgot to mention
www.vplates.com.au
Up coming section of VicRoads website to check licence plates and order them etc.
It's not up and running properly yet but thats the site anyway
I just got "I R SMRT" in the mail yesterday :)
cool, how'd you get SKYGRL in the end? I remember seein this indian chick that works at safeway in springy with em like a couple of years ago.
isnt that SKYGAL? i am pretty sure it is....i have seen it a few times now
yer I thought she had SKYGRL and that I would have to settle for SKYGAL, but when they said that was already taken, I realised she had that and I could get SKYGRL
i know u said not to get similar to her hehe
but I doubttttt I could be confused with her lol
i was surprised to see it was actually available...
its on my list of plates to consider once i get my skyline
and for anyone thinking "oh ill buy it and sell it to this guy for a nice profit" go for it. i dont want it that much ;)
ive got quite a few other model specific that no one seems to want :D
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
