I had a great night at wsid last night even though I only got 3 runs in before being told to get a super street license. I was driving the Midnight Purple R32 GTR with ZILLA plates.
My times were:
12.036 @ 114.05 mph, 1.858 (60')
11.981 @ 115.81 mph, 1.858
11.946 @ 113.34 mph, 1.822
I achieved these times using average quality and condition street tyres and running the car in full street trim including same boost I use on the street (19psi).
Some mods include:
R34 N1 Turbos
PFC
Twin plate clutch
Happy to now own a TRUE 11 second street car !! :D:(
Tim.
https://www.sau.com.au/forums/topic/82151-wsid-2707/
Hi BU5TER, yeah i live not far from steves shop and i was getting some work done on my old pintara when i noticed your car there. Your motor looks very impressive, cant wait to see it run. Had a good chat to Steve about it.
un_majstk, I cant realy tell u what it cost as most of performance gear was already on the car when I bought it. I have spent most of my time and effort painting it.
Tim.
https://www.sau.com.au/forums/topic/82151-wsid-2707/#findComment-1489787
I was there but can't remember a midnight purple gtr... did you run up against a gunmetal grey r32 gtr (which I think blew an IC pipe on 1 run) ?
Yes quite a few r32's there on wed nite including 1 that was for sale:
1992 R32 GTR
'HKSGTR' nsw plates
~160,000km (not aware of any rebuilds and had the car for 2yrs)
Gunmetal Grey (2wk old respray)
PWR Radiator
Splitfire Coils
Std FMIC (with HKS written all over it)
PowerFC + H/C
A few gauges
~360rwkw
~$30k
Aftermarket rims
Redline engine/gearbox/diff oils
Very neat inside and out
0402772703 if anybody wants to call him
It was his first time there with the gtr, his best from memory was 12.0 and was doing pretty consistent 12.4's @ 110mph with very average launches (1.8-1.9 but bogging down).
https://www.sau.com.au/forums/topic/82151-wsid-2707/#findComment-1490915
The VL had a set of brand new tyres and the driver wasn't going to stop until either the engine or the tyres blew. The Nissan engine did well. :rofl: Definitely the longest burnout I have ever seen. It was done in memory of his younger brother who passed away at 16 last month.
https://www.sau.com.au/forums/topic/82151-wsid-2707/#findComment-1491107
If you didnt see me that may be because I was finished all 3 of my runs by about 7.15, so we then parked the car and sat and watched. Didnt want to buy the super street license as I achieved my aim for the night and iam a bit short on cash atm.
ECR033, yeah mph was a bit down on last run. I think this may be because I hit the limiter in first. I gave it a few more revs on that launch and it surprised me how quick 2nd gear was needed.
Tim.
https://www.sau.com.au/forums/topic/82151-wsid-2707/#findComment-1491693
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
