Hi every1
I am new to SAU but have had a 34 since last november.
I just wanted to ask if anyone knows how to make all 4 taillights work when ur braking?? coz currently only the 2 bigger lights only light up.
Sorry if this has been covered before but i tried a search but no luck..
any help is greatly appreciated
thanx
https://www.sau.com.au/forums/topic/82175-r34-taillights-when-braking-help-pls/
  • 1 year later...
So let me get his right, stock standard out of the factory:
2 doors: only have the 2 outside (bigger lights) light up
4 doors: all 4 lights light up
I always thought that compliance changed my car so that only the outside 2 lit up, perhaps this is not the case then.
Yep... that's right, and it's wierd isn't it.
I saw a 4 door hitting the streets with four stove lamps and thought somethign was wrong with mine. Came home checked and there's no double element bulbs in the inner stoves. :) Sucks.
what about with parkers just on? do the four doors only have the two bigger lights light up when the parkers come on or are all four supposed to light up as well?
all my tail lights come on at parkers chris, yours should also
Mine dont only the outer lights do. Ill get into it on the weekend and see if Ican fix the problem then. It just doesnt look like a skyline without all 4 of them.
Correcto
All four still light up always.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
