i reckon they rice every car and makes it look ugly
it should be rice and the ridculous back wif more rice den ever
they even riced the amercian cars. The lanevo has clear tailights like is200 omg how can they do that
well not meaning to dis the movie but just don;t like what they do to the car, its good to see a car movie though now and then.
absolutely loved the first, cant wait till this part 2 cums out.
its good to c that they have more skylines in this 1, and ofcourse a 180.
didnt c any evo's or rexies though.
should be good. heard vin diesel isnt in it though cause he was filming pitch black 2.
wouldn't it be awesome if nz and serious performance did a similar thing. Ketzal Sterling could finally act out his dream although the accent would stufff it. But imagine cars like flyen,osmans,ghhost,yume,try09,denzo's whole collection etc with a bit of a plot and a bit of drift wars and drag action. I guess I'll have to wait for that phone call for me to direct it hey!!!!!!!!!!
for starters the clear taillights were out in america LONG before they put them on the IS200
go hire out the movie Edward Scissor Hands and look at the wanker in its van.
i don;t have any thing against clear tailights
its just an evo is an evo it is already good the way it looks like you don;t see that everyday you wouldn;t go put clear tailights on a skyline gtr would you. It just wouldn't be a gtr we come to know.
although they have released an evo7 autotech or something along those lines which has auto transmission and clear tailights so yeh.
OH! MY! GOD!
Is that a neon tube in front of the intercooler on the R34? (see close up)
Oh great earth, open up and take me know!!
wtf is this world coming to. If that is a neon tube, the owner and however fitted it should be shot.
Originally posted by Boxhead
is that a skyline???
looks sorta yes and no.. who knows...
its some sort of honda in america which the person had converted into a skyline the front and back its a replica.
The lights just give an indication of what clear tailight skyline lights might look.
here is another skyline wanab.
But let's not forget that the neon tube in front of the intercooler can actually INCREASE the airflow thru the cooler - depending on what colour it is :bahaha:
I'm gonna guess that one of those 34's gets blown up. That's what they did in the last movie with the little green Eclipse. Made a couple that looked identical and blew 'em up...If they do it this time - it'll be a sad day...
I wonder how you can drive with your front windscreen covered top to bottom in stickers. :freak:
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
