I've seen a car with a maxed out AFM and they get a tune and the air flow meter was working oerfectly with more boost and more power before ... how does this work? Is it tune dependant somehow? How can some people make 360+rwkw on a Z32 yet other say their only rated for just over 250 rwkw?
https://www.sau.com.au/forums/topic/82284-z32-afm/page/2/#findComment-1533046
Mercury Motrsport still run AFM on their S15 with a GT35R, and theirs isn't maxing out ... it just seems strange that a near stock Ser II R33 will max out on 10 psi boost with a stock turbo and stock AFM .... Z32 aren't that much better. I know their better but not by that much.
Edited by ookami
https://www.sau.com.au/forums/topic/82284-z32-afm/page/2/#findComment-1535266
I was going to start a thread, but this seems close enough =)
AFM1 on my 32GTR looses half its voltage compared to AFM2, then clicks back to normal. I reckon if I’m going to replace one, I should upgrade both.
I have a couple channels of thought here,
1] Does the Z32 flow a worth while more then the stock ones? I can get replacements for 180 each, and Z32’s for 300 each; can anyone with experience tell me when ( ie, mods boost, RWKW) does a RB26 run them out of useful resolution?
2] The above is second hand, and don’t you HATE spending money on sh1te that breaks. So I have been looking at new prices *gulp* for Z32’s from Nissan and the Nismo branded AFM’s
greenline.jp quote
“One air flow meter. Twin NISMO AFM setup: 2400kg/h (Approx. 775ps). Twin standard AFM setup: 1400kg/h (450ps). Requires ECU retune.”
Nismo say 775ps ( (775/1.34=578kw) x .70=405rwkw), SydneyKid (511rwkw) and then R31Nismoid 369rwkw on a SINGLE.
I assume The 369rwkw could have been from PFC AFM reference voltage and fuel map tweaking, with SK’s 511 seems more likely, but my question is, when do people hit their Z32’s, Nismo’s or stock 26/25’s voltage limit? RWKW would be helpful too.
Any help would be massively appreciated!!!
- RKaida
https://www.sau.com.au/forums/topic/82284-z32-afm/page/2/#findComment-1535769
To my understanding "supposedly" when you run out of resolution on twin z32, you'll need parachute to stop your car, but I have ran them out of resolution and I probably can do the fred flintstone thing to stop my car. Since then, I have the individual intake pipe velocity tested, and it was found that one tract was more efficient than the other, this is what is causing the anomalies in my AFM resolution.
So answering your question geeTR, you'll have to wait till I get new tracts made up and retune to precisely answer your question, other than that' I'm just about over the power fc and going full autronic. LOL
https://www.sau.com.au/forums/topic/82284-z32-afm/page/2/#findComment-1540508
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
