It's a friction clip, just pops out. I had the same trouble, but i also had to remove my eyelids to get it off. same as the rear lights, they feel like they're going to break off, but it's just a really tight clip
Once it is loose you should be able to get a screw driver in the gap behind the parker light, use a torch as well and try and leaver it off a bit, getting as close to the clip as you can, after a lot off pulling and leavering it should just pop off, feels like its going to break, and then you'll say OH it was just that little dam clip. :hellpisd:
  • 1 month later...
do the headlights need to come out, too get the parker globes?
Nope, just undo the philips head screw that holds the parker assembly onto the top of the headlight assembly. Then pull the parker assembly straight forward by slipping a couple of fingers behind it. It is very tight, just make sure you pull it straight, not up or down or outwards.
:wub: cheers :wub:
Edited by Sydneykid
  • 5 months later...
:laugh: cheers :laugh:
My parkers are blue in colour and when I was at a petrol station earlier this week, a cop mentioned that I should change them. I think it's better to be safe than sorry rather than risk a defect.
Tried to get my parkers off last night, and again tonight after having read this thread. I tried pulling them out with a bit of force after undoing the Phillips head screws, but thought I'd better check with those who've already done it before I break them.
Do I pull them forward towards (but away from, if that makes sense?) the front of the car, and can anyone please post a pic of where the clip is and where I should put a screwdriver to lever it off (without scratching the paint)? Is the clip behind or below the parker?
Thanks in advance...
Nick
from memory.. i was pulling forwards away from the car...
and i had the screwdriver pushing with my other arm from under the front bar.... i think i had to jiggy the washer bottle.. this was the left side...
the left was a bitch.. the right popped out without fuss...
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
