Guest DIRTgarage
"Girls are weak...chuck em in th......."
What'd I miss?  Stace?  Mona?
Anyway...
The two WOMEN who raced at the drag day on Sunday have taken well over $5500.00 in prizemoney between them at drag racing events over the last 18 months and that deserves restec-p of the highest order.   :D
They are two of the most well-seasoned drag racers that SAU has the honour of calling members and should be regarded as such.
I don't think people give them enough credit - in particular regard to the skills they have developed.
For instance, Mona.  How the HELL do you cut sub .020 lights every other time?!?!  It's got me beaten.   :(
Everyone have a good hard look at who the REAL racers are on this forum and in this club and then, if you're nice about it, draw from their experience.  I'd like to.
Adrian
  • Replies 275
Posted Images
That's cool Moanie, i have told Brad on numberous occations not to say anything about my car, especially on-line but he can't seem to help himsef.
At the end of the day i have the upmost respect for yourself and stacy for taking it to the guys on the strip like you do and coming out on top. The trophies proudly displayed infront of TWO 06L at the show n shine and your times etc have proved that and i'm sure it will continue.
BTW Stace and Paul, good luck for Jambo. we will be there cheering you on :(
I didn't realise that the video's I posted were all corrupt (my FTP program spat the dummy when uploading them). So i've just re-uploaded them all and I believe they are working fine now.
You will need to download 'Divx 5' in order to view them as they are a highly compressed format. You can get this from: http://download.divx.com/divx/DivXPlay.exe
My video's are located: HERE
Guest two.06l
Hey Ben....i think you had better change the video title to Stacey.....as it was me driving the car on that run.
Stacey: done
I've just added another 8 video's (that's all of them done). Once again they aren't fantastic quality but i'm yet to see any other video's posted (well 1 but that was a media guy).
Download them from: HERE
Guest two.06l
thanks MSRB 26 .........lookin' forward to having a run against you. Still trying to organise things for Jamboree. Getting TWOOGLE there will be the main problem.
Thanks Benm for the vid. You can really tell that is me, totally bogging down off the line. Have to learn to bounce it off the limiter to get the boost up high enough.
Transporting a car up there is a pain, which is why i'll never be taking the car up there. If you get stuck there is normally a transporter leaving from Newcastle with RX Engineerings drag cars who may have a spare spot, might be another option for you anyway :P
U HAPPY YOU GOT WHAT YOU WHAT NOW PRINCESS???
WHERE IS THE SENSE OF PRIVACY IN THIS F****D UP PLACE, IF YOU GONNA CHOP AND CHANGE STUFF AT LEAST HAVE THE COURTESY TO INFORM ME PRIOR AS IM PERFECTLY CAPABLE OF DOING IT MYSELF!!
WHEREZ THE F****D UP CLAUSE SAYING I CANT HAVE THAT F****D UP LOGO UP!!!!!!!!!!!!!!!!!!!
you found that sig yet princess
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
