It turns out I didn't blow the turbo, I blew off an intercooler pipe. But I couldn't see it on the night cause it was under the car and dark. But the turbo is definetly on the way out cause theres oil in the intercooler pipes. I'll drive like an old woman for a month or so and replace it with something a bit bigger. :D
https://www.sau.com.au/forums/topic/8271-hicks-is-happysort-of/
Originally posted by KILLER-T
I think a bit of oil in thr cooler pipes is normal if you are running a bit of extra boost just buy a oil catch can :D
im not too sure, I've had the pipes off quite a bit, when i painted them and polished the intercooler. also had the inlet pipe off when I changed the plugs(c#nt of a job) but theres never been oil in there before.
So what is new Hicks??:bahaha:
Good to see that your car is just barely alive, but I agree with Killer-T that it is probably not that much too worry about, but if you need an excuse to drive slowly then its OK with me.
See'ya:burnout:
It's scary when you blow a pipe off, does make you think the worst. I blew a vacume hose at the plex last time and I thought it was a dead turbo too. I had a look under the bonnet and found the hose, went out and kept dragging :D
Seriously sounds like blow by, this can be increased by increasing boost, or even using a oil thats a bit too thin when you change it. Would investigate a catch can as coating your coola isn't a good way of improving efficiency:D
Good luck getting it sorted - only if to get GTS-t VSPEC off your case....hehehehe.
Steve
Originally posted by GTS-t VSPEC
I never had oil in my pipes till I ran higher boost.
I run standard boost and have a bit of oil.
Catch-can you say ?
BTW: My next oil change is due shortly, what does everyone use/recommend ? and how much is it ? (also, how many Ls to fill up?)
-Kym.
Hes ripping u off m8.
U change ure oil every 5000ks right? whats the point of puttin redline in (unless ure a sheik or something) just use good ol Mobil1 synth half the price and will be dam close to as good as redline for that time period.
Its not just the oil in the pipes that worried me, its the way that smoke slowly rises from the exaust when I back it off after reving it.
BTW paul, your a tool. I might head down to the plex to watch you get some more 14 second passes. :(
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
