While you are approaching a red light at 80km/h in 5th Gear on the hwy
59 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
80-0 on freeway, if its just a cruisey slow down then i would prob use mostly brakes, drop it into 3 then brake some more then neutral and stop.
same process when at 50/60 in city when stopping slowly
but when stopping hard thats another thing all together!
When i was learning to drive i was told i'd fail my licence test if i 'clutch coasted' to the lights. Had to downshift.
Besides gear breaking is kinder to your brakes (although less kinder to your engine :lol: ). I look at it in an emergency situation, someone outta nowhere rams you from behind and you're in neutral you'll go flying, in gear there'd be more resistance, plus it'd be quicker to put your foot down and get out of their way if you saw them coming as you wouldn't have to shift back into gear or risk the car bogging down while you attempt to take off in fourth or something....
Having said that i usually do a combination of both. Downshift then clutch coast the last few metres.
yeh i was taught to always have the car in a gear, ie the correct gear for the given situation.
as konrad said, saves getting stuck in a sticky situation, also makes for better practice if you want to learn how to race on track.
having said that, i do get lazy in traffic :)
When i was taught by my driving instructed he told me always to go from 5th,4th to 2nd... when comming to a rounderbout or a set of lights, form their its a slip into first when under <20k's
Even though i always used to just go to neautral, i found that its more enjoyable going down through the gears:D
Dayne
Say im cruising up to a red light in 4th for example, I usually just cruise up to it using no gas but fully in gear, then when revs get to about 1,000rpm I will clutch it and stop the car using the brakes.
I dont see the point in downshifting unless its really heavy braking. In my opinion its just more wear and tear on the clutch/gears.
Coasting as soon as you see the red uses more fuel than leaving the car in gear as the car must use fuel rather than the wheels to keep the engine turning over (so i hear).
Is this like a smart or dumb realisation joke or sumthin.
i clutch in.
cuz u have to clutch in to down shift or to put it in neutral, if u dun wana wreak ya sincro's...
or am i just a smart ass?
Indeed you are :)
if im ages away from the lite i just nuetral it and coast along til i just break lightly and if i pretty close i down shift.
when my old girls with me she doesnt like it when i down shift coz sometimes it jolts!
Neutral then coast to stop. But then I have a habit of putting it in neutral whenever I can, love those downhills.
Gt_t_34 to stop it from jolting when downshifting, put it in neutral, tap the gas so rpm goes up around 1k then downshift.
Say you're in 4th, go to N, blip the gas then go to 3rd. It will be as smooth as an auto. Sounds awkward but its easy and becomes second nature.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
