Do any of the boost controllers allow you to set boost levels depending on RPM?
For example - supposing I want to limit boost to 1.2bar at 5000rpm and slowly ramp boost up to my maximum boost of (for arguments sake) 2bar at 8000rpm?
The reason I ask the question is that since boost is "resistance to airflow", as you go up the RPM range, the valves are only opening for much shorter periods, and so while you are reading say 1 bar at 6000rpm, you're probably only getting half the amount of air in as you are at 3000rpm when also running 1bar... ( is that theory right?)
So I was thinking that an engine under load 4000-5000rpm might not like 2bar being belted into it, (a bit like a shot of nitrous too early in the revs) but could well handle it up around 7000-8000 rpm?
If a boost controller is set at 1.5bar to "suit" the 4000-5000 rpm range, then am I getting less and less air into it at higher revs as the valves are opening and shutting faster and faster and hence building up back pressure? (ie reading same boost, but getting less air-flow?)
Thoughts?
https://www.sau.com.au/forums/topic/83235-increasing-boost-with-revs-airflow/
ACV-R can do that in intervals of 500rpm
Ah - so it does! (just looked it up)
I have a basic HKS boost controller which doesn't - and I only ever see people quoting max boost.... so I wondered if this sort of thing was played with much..
Sorry if it was a dumb question! I come from a normally aspirated backgorund and am still learning. :)
So would this be the norm then?
Are people out there tending to raise the boost as RPM goes up?
cheers,
An engine at 6000 rpm is eating twice as much air as it is at 3000 rpm. That has nothing to do with boost.
Some people, myself included, use the rpm based boost control of the AVC-R to smooth the ramp up of boost to control wheelspin in 1st gear.
You don't have to do it that way - the AVC-R has a gear learning facility and you can use that to limit boost differently per gear. That way, you can have your full balls out mode in the higher gears while limiting it in 1st to stop wheelspin.
I think it works out what gear your in by looking at rpm vs road speed.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
