Standard internal Rb20 2 litre that is r32 spec , with a high flow vg30 turbo truck core front mount dump pipe. Some 'mines' ecu a few little mods pod etc, blitz boost controller 290 at the wheels.
I have hit some type of cut, Speed signal cut is the theory at the moment. the dyno graph was heading up still when the power was cut on me. This is on 18 psi. This was at barry's dyno, this arvo.
Enjoy :shake:
https://www.sau.com.au/forums/topic/8331-290-at-the-tred/
Guest KILLER-T
Hey this might sound like a stupid question but at what speed did u make peak power.I'm only asking because i had my car on the same dyno yesterday and the peak power and kmh dont add up
By the way top effort with your power output you have to be happy with 290rwhp well done:uh-huh:
https://www.sau.com.au/forums/topic/8331-290-at-the-tred/#findComment-120468
Guest KILLER-T
Ok it made 304rwhp and 1650 lb torque running 1.08 bar i still didnt get to see my car running 1.25 bar i cant work out why it dont boost as hard on the dyno it must have something to do with load on the engine anyway he didnt do a tune we just put it on the dyno to see how it was running. Barry said he would like to pull a bit of fuel out of the fuel map and then i will see a bit more POWER i will go back in a few weeks once i have some more cash
:thumbsup:
https://www.sau.com.au/forums/topic/8331-290-at-the-tred/#findComment-120488
yeah nice power there guys, specially from the RB20 :thumbsup:
a quick question.. FRIGGIN FOOT-POUNDS for torque.. WTF, i dont get it.. is it a straight forward linear conversion like HP-KW or is it logorithmic?
the reason i ask is on the aston martin website (checking out the vanquish after watching bond last night :mad: ) it says the car has 400ft/lb = 541NM..
linear, that would give your car ~2200NM, where'as a LS1 is only 500NM or so.. i dont get it..
someone care to explain?
Shaun
https://www.sau.com.au/forums/topic/8331-290-at-the-tred/#findComment-120734
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
