Well as the title suggests I am selling my old beast in AS IS condition with no roadworthy, no warranty just as is.
It is a 1990 Ford Falcon EA, and it can be yours for $200 ONO!!!!
Basically it probably just needs a windscreen, a battery and some new tyres and it'd pass roadworthy but I just coldnt be bothered.
Has Alpine head unit with 6 stacker in the boot with 2x 120W 6x9 Alpine speaker
2.5 inch Extractors and full exhaust system
Rego runs out on the 14th of August.
Here are some pics:
Front on:
Backend:
Drivers side from front:
Drivers side from back:
Inside Front:
Pedals, including BIG FOOT Accelerator ( Thorpy say's it's fooly sic hey bro!):
Cluster set, including smart arse cockaroach who played peek-a-boo with the camera:
Mags and tyres, which are not totally bald, not on steels but still illegal:
Engine Bay, with no serios oil leaks, typical ford tappet cover leak though:
Exhaust extractors, 2.5inch goes with the 2.5 inch exhaust system, with chome tip for that ricy goodness:
I do not need to know how much of a crapbox this is, but it drives and probably needs little amount of work for someone who is a mechanic, I just couldn't be bothered.
Would like to get rid of it preety quickly so make an offer, all serious offers will be considered.
Contact Cyrus on 0404 084 695 (AFTER 6pm as mobile coverage at work SUCKS!)
OR [email protected]
https://www.sau.com.au/forums/topic/83340-omg-whole-car-200/
hey cyrus
How much of a easy fix is it, what sorta things does it need replaced just so I can get a idea of how much money it will need oh & can you put a tyre size up too please
If not to much We will be interested :P
I'm no mechanic and if you want to pay for it to be inspected then by all means do.
Only things I know are wrong with it that would affect roadworthy are:
1. Massive crack down windscreen, will need replacing
2. Battery dead, barly holds enough chagre to start, sometimes doesnt
3. Tyres are below legal tread mark, will need replacing
Other than that, the car drives fine, idles fine, the auto doesnt clunk or anything, no mystery noises when braking or turning.
Oh the aircon needs a re-gas, and the tint is stuffed on the windows.
To me it is not really worth fixing up when you can buy them in really good nic for around $2,000.
Very negotiable on the price too...... make an offer :P
This car would be perfect for a track/bush basher.
And whack this on:
http://cgi.ebay.com.au/FORD-EA-AU-STAGE-4-...1QQcmdZViewItem
And apparently BAM, 400hp :)
Still for sale btw!
I'll even throw in the:
GET IN
SIT DOWN
SHUT UP
AND HANG ON
Foot mats!!!!!
FOR FREE!!
BARGAIN!
lol, i should buy a heap of shit like this so I dont drive my new skyline to work everyday, 100km round trip minimum once a day 6 days a week...sometimes twice a day...
ill have a think about it, and those mats sure make it tempting!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
