what noise does it make ? im not to smart on bov's
If it's the one I think it is, it makes like a "ft-tsshhhh" sound. Haha, I always laugh when people try to make blow off valve sounds over forums and here I am doing it :)
https://www.sau.com.au/forums/topic/83507-gfb-hybrid-bov/#findComment-1510911
If it's the one I think it is, it makes like a "ft-tsshhhh" sound. Haha, I always laugh when people try to make blow off valve sounds over forums and here I am doing it  :(
"broooooooooooooooooooooooooooooooom tutututututu"
whats that 1 called? i like that 1 :P
https://www.sau.com.au/forums/topic/83507-gfb-hybrid-bov/#findComment-1515501
thats a blocked bov + pod filter
blocked?
imaybe i didnt type it too well...the only thing ive read on here that sounds like its describing the BOV i like is super sequential...
i thought there was 2 sounding blow off vavles....the 1 that is basically a big sneeze...and the 1 that is like a series of 3 or 4 small "sneezes"
https://www.sau.com.au/forums/topic/83507-gfb-hybrid-bov/#findComment-1518823
    • Talk to hot girls via live cam. Adult dating made easy and exciting. https://secrelocal.com private ladies for discreet encounters
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
