I'm having real problems with temps at the tracks and was wondering about getting a carbon fibre bonnet with vents. Anyone have any experience with holes in bonnets? Also where else can I get one besides unique? Like to keep options open.
https://www.sau.com.au/forums/topic/8357-vented-bonnets/
You could have your own bonnet vented fairly cheaply I'd imagine. Then again for $1000 a carbon one from UAS is hard to beat. Proper all carbon fibre bonnets from Jap land can cost $4k+.
Have you upgraded the radiator?
Make sure the water pump is not too old, most have been replaced when the timing belt is done at 100,000kms.
The water pump can cavitate the water at high rpms as well, running a slightly under driven pulley kit like the one trust do would be an idea as well if the car is going to the track a fair bit.
https://www.sau.com.au/forums/topic/8357-vented-bonnets/#findComment-120808
I liked the look of the carbo fibre bonnet from Unique, just waiting for them to make one for the Series I R33. Has anyone actually put one on, what is the fit like? Does carbon fibre fade in the sun?
If your into circuit racing then I think a bigger radiator is a must, the vented bonnet will definately help reduce the temp aswell.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8357-vented-bonnets/#findComment-120832
I think that the pulley idea that rev210 mentioned is good, cavitating pumps are useless and the will cavitate more as the temperature increases.
It does seem a wank that a vented bonnet draws so much attention, even factory cars like Evo's have been stickered for the vented bonnets. I don't see what possible law that they break, except bad taste in some cases.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8357-vented-bonnets/#findComment-120843
I believe that UAS get their carbon bonnets from Carmate in Lansvale, Carmate are selling the bonnets for around $900 maybe even cheaper.
With the carbin bonnets it does get rid of all the heat in there fairly fast.
Carbon doesn't fade in the sun, well not yet anyway, I've had mine on about 5000km but it will need to be clear coated. The bonnets actually only have a gell coat on it and to keep up the looks and reduce the dull it will need to be slightly sanded back and then clear coated.
hope it helps.
https://www.sau.com.au/forums/topic/8357-vented-bonnets/#findComment-120846
Originally posted by 51jay
Silver-Arrowz  have you thought about an electric water pump.
I replaced my pump about a month ago along with the timing belt cost $150 Nissan item.
At one point it did cross my mind, however some folks on SDU said they are prone to electrical problems. I also had the idea to remove the mechanical fan and put electric fans, however this also has the same problem.
https://www.sau.com.au/forums/topic/8357-vented-bonnets/#findComment-121026
Silver-Arrows.....I know it's full sick, but, DON'T put on the 747 wing. My mate had a really bad expereance going over the Gateway bridge at 110kph in a very slight crosswind. By rapidly juggling between high and superhigh boost he was able to land it almost undamaged on Cleveland Rd but now he has a bad twitch and a tendancy to spill his beer whenever he hears a plane go over....He replaced it with the really high GTR wing with 2 intermediate wings and a bootlid lip. It looks really really smick and shows no signs of ever taking off.
https://www.sau.com.au/forums/topic/8357-vented-bonnets/#findComment-122430
Mick51,
I was only kidding with fatz. :lol:
I really want a sleeper, so no kit or wing is being bolted on as long as I'm still the owner of the car. The idea of the bonnet was just purely for the race track, nothing more. Yeah I know which bridge your talking about, I went past there before and OMG, it's so f*ckn big
https://www.sau.com.au/forums/topic/8357-vented-bonnets/#findComment-123282
If you manage to find a good deal can you please PM me. I have been hunting around and have found carbon fibre ones mostly going for about $900 - $1000 (UAS seem to be good) or fibreglass painted same colour as my car for $900 - $1000 or about $700 if i hack up my own one....
tryin to find some better prices than that at the moment...
https://www.sau.com.au/forums/topic/8357-vented-bonnets/#findComment-123312
Silver-Arrows.......with a vented carbon fibre bonnet your sleeper days will be long gone.
I have the same thought ...but where is the right place for the vents. I'd like to do something to help with the heat soak when you sit in the staging lanes for 30 minutes, Wed 1st at Willowbank it was over an hour between runs and that was if you went straight back around.
Do you know what the stock bonnet and boot weigh?? they'r pretty hefty
so far Stock 16ins mags with 205 50 tyres 19.25kg each
https://www.sau.com.au/forums/topic/8357-vented-bonnets/#findComment-123492
I meant sleeper on the streets.
25GTT, I went looking around today and found that Car Mate are asking for $1050 for the same one as Unique. I didn't get to see it in real life but I'm not too impressed. Jetspeed are getting some in at the end of the month and have no idea on price.
I will keep you up to date.
https://www.sau.com.au/forums/topic/8357-vented-bonnets/#findComment-123493
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
