  • Replies 520
Posted Images
freakin r33 gts-t box still has not arrived. very good chance i shan't be having box in in time for this drag day. if so, it's goodbye to slicks, and hello to numerous pairs of street tyres which I plan to destroy.
doodz. All the relevant info on the Drag Day is in the first post.
But I will help you out here:
Track opens 7:30am
Sign on 8-9:30am
Driver briefing 10am
Racing 10:15 to 1pm
Lunch 1-1:30pm
Racing 1:30-4:15pm
This time there will be 2 crew, 3 spectators and 1 photographer permitted per driver. The photographer is nominated so as to avoid too many people milling around the pit area.
I have just read the words "per driver" in your quote.
Because my car will have two drivers do I double the crew, spectators and photographers ?
I hope so as I am paying nearly double the fee.
Would like this clarified by anyone in a position to do so.
El Bee
Ok the man with the answers is here.
elbee - your second driver actually takes the spot of your first pit crew.
doodz - you can come with me but no friends unless other entrants put them on their lists because I don't know them. In return you can help me with the bbq and drinks stall. We need a couple of other helpers too people.
Parking is no problem.
That sucks. What have I paid all this extra money for ?
There are spectators that I would like to invite, and spectators that my Son (2nd driver) would like to invite.
NXTIMEs quote clearly states "per driver".
El Bee
ps. Didn't pay any extra for 2nd driver last time so understood then. This time is extra $100.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
