On friday i drove down to where Maltech are and i got some custom made SS braided brake lines.
Being the first with the stagea there, i was a guiny pig and it took a little longer then expecteed.
The fronts are almost identical to R33 GTR lines, but there is an extra hose that is needed for the Stagea. The rear lines are completely unique to make.
I have to admit i was a little skeptical of it at first, but once i drove off for the first time, i noticed that teh ABS under soft braking was locking up on the same dirt road i came in on. Driving on the fwy back home, i did some braking tests. The difference is quite amazing. The biggest improvement was in the precision of the brakes. Before, where i was in D i could either slip the brakes till the car would move or for it to be stopped. Now, the brakes can slip a tiny bit, a bit more and bit bit more... big difference to me.
Additionally, they are not too hard to install. I was watching the guys do them, if i was buying a kit i dont think i could call it a hard job, not SIMPLE though (need to know something about brakes)
Anyway, i am not sure what price they will release the kits at, but for the moeny, i think its really worth it. The difference between lines and pads are that the lines are there forever, a never wearing performance upgrade (ie, dont replace them like better pads or rotors)
Nice Work! Braided lines are an awesome upgrade.... Ive got a set on my Fireblade and they have made an unreal difference (just waiting to receive my wave rotors and I'll have the best brakes in the business!!). :lol:
Better braking 'feel', obviously way less flex than with the original rubber lines, and they wont breakdown over time.
Bet they feel awesome! Add a set of xdrilled slotted DBA rotors and topspec sinstered pads and your brakes will be as good as they can be (besides spending big $$ on Brembos)! Good stuff.
Only thing is, are the ones you had made up ADR approved and certified? Im sure it wouldnt be a problem if they arnt (the set on my bike arnt, they were from USA). :P
You'd have to be unlucky to be done for having them on the car, but would obviously be a defect if picked up if they arnt ADR approved.
Still, good stuff in taking the plunge and having them custom made for the Stagea....... B)
Brendan
www.maltech.com.au
I watched them make the hoses in front of me. They are ADR approved and all tested to 3500psi on this machine thing. (pretty cool to watch)
I had to drive 2 hours and 200km to get to the guys....pissed my girl off quite bad...but it was worth it in the end.
Next thing for me, discs and pads.
Im longing for some power mods, but stupid shipping from japan takes too long :P
Got prices,
"We have worked out the price for the set which will include
8 Stainless Braided Brake Hoses ADR Approved
4 Banjo Bolts
8 Copper Washers
Retail $465.00"
Here are some pictures of them installed on my car.
Front has two parts the it. The small std hose with steel tube was replaced with a new hose.
Fronts
Rear
I honestly reccomend the upgrade for anyone.
  • 10 months later...
Hi Guys,
If you are after stainless braided brake hoses we can now supply them with coloured plastic coated braided hose.
Picture shows plastic coated colours and insert colours
Ive asked for a quote for fronts only
:D
i think i missed something. pushing the pedal won't help if you have no rotors or lines, no matter who's foot it is
wilma and fred did it, even with bambam and pebbles in the stag.
lol
let me rephrase
the aftermarket braided lines, aftermarket pads and aftermarket rotors will all be sold.
the stock lines, stock pads and stock rotors will all go back in.
I dont throw away ANYTHING that i remove (unless its well and truely dead/beyond repair (aka, old bushes))
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
