  • Replies 40
gtst25,
one thing i didnt get in my kit, either that or its not meant to be included, was a gasket of any kind for the exhaust turbine housing/dump pipe flange? there is a groove in the exhaust housing so we made up some copper wire to fit exactly as pictured... it probably doesnt need anything, but i didnt want to have to pull it off again incase there was a leak.
Edited by SLY33
gtst25,
No gasket in my kit either. The copper wire looks good though - would squash down nicely and heat wouldn't bother it. What does everyone else do?
I'll get dad to take some more photos of the turbine wheel bare and some measurements.
Thank you very much great feed back . Pics of the turbine end on and from the side would be great .
While I'm here the numbers on the ID plate would be interesting , my list shows the cartridge or CHRA number as 700177-0003 for th 84 trim turbine and 56 trim compressor . The turbine should merasure 51.6 by 56.6mm (84T) and 53.6 by 56.6mm for 90 trim .
A couple of things to note , HUGE vent for the waste gate (2835) and the model specific outlet flange pattern on the HKS 2530 to suit the RB20/25 dump pipe .
The thing I'm really curious to know is if the HKS GT3037 Pro S has a divider between the turbine outlet and the waste gate vent hole as the turbine outlet is larger again and there's not much meat with the 2835 housing .
Cheers and thanks A .
3037ProS is an external gate only isnt it?
It'd have to have a divider between the turbine exit and wastegate - hell if it didn't you wouldn't have to bother with a split dump pipe - the gasses'd be mixing before they get there. Maybe they can move the wastegate over a bit away from the turbine but if they did that it'd still be a big job to get the housing looking right??
How much larger is the 3037 than the 2835?
hey sly33, has the problem been solved about the gt2835 pro s when it is boosted to 20psi then drops down to 18psi....?
ive noticed a few people saying thats when it boost's to 20 or above it always drops down to 17-18 , i was wondering if it had anything to do with the internal wastegate...?
ID plate numbers:
IA 0156J
GT2835-56T
100177-5003
Turbine dia: 51.17mm top, 56.5 bottom
wastegate dia 35mm
inlet compressor 100mm
outlet compressor 50mm
It's amasing how small the thing is - it must spin like crazy. The turbos on the boat I work on spin @ 56000 rpm - 2070KW per engine. That's nearly 1000 times a second - pretty hard to imagine hey?
Edited by gtst25
The inside of the turbine housing?
Does it have daggy cast marks etc or does it look as if its been cleaned up or possibly really good castings?
I've seen garret items that look pretty messy inside. Bolts poking through in to the comps airflow stream etc.
Edited by Cubes
I'll get dad to have a look when it comes back from ceamic coating.
I don't think he wants to take the compressor cover off - if he dropped or bumped the wheel the wrong way my new turbo would probably go out of balance.
probably upwards of 120,000rpm.
more to the tune of 150,000rpm+
I see the Bandag bullet's turbos goto 180000rpm.
On our MTU's we've got turbo rev counters - must have a magnetised part of the compressor wheel and a sensor bolts into the compressor housing. They run 3.6 bar boost press @ full noise.
Mario dont tell me your getting this turbo ?? haha
Heard you were going for some Apexi item ????
hahah im just intrested thats all ... i was just wondering why it does it ..i was reading from grepin posts with this turbo......yes im going apexi high mount see what happens .
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
