cheers for uploadin the vid. twas a rather good day, i came 3rd in class and 11th overall. not as well as id usualy like to do but i had a s**t load of fun and my UsedTyreMart tread is still road worthy.
https://www.sau.com.au/forums/topic/84158-motorkana-vids/#findComment-1524463
Its also a 5speed.
My others halfs brother has a lease VRX 5 speed from Mitsi's.
I'd say it pretty much is as fast, the bottom end poke of the little 3.5ltr is amazing from such a small motor.
Quite silly having such a motor in a FWD, rolling on in first has the front 225's smoking by simply mashing the pedal, pretty much you always have to drive around with traction control on unless you are good with throttle control.
The latest model is really good with regards to torque steer, the older shape had you hanging on for dear life with white knuckles as you pulled out of a corner.
But.. its still a fwd Magna.. :P lol
Move back to RWD and drop a decent twin charged 3.5ltr in to it and it may sell a little better. :(
https://www.sau.com.au/forums/topic/84158-motorkana-vids/#findComment-1525821
That magna is owned by the mitsu plant, and is given to the driver with a new set of tread every event. He has many years of motorkana's behind him and is employed by the mitsu plant.
ps, the event before the 14th (round 3) my mate drinkies (blue four door R32) was second overall, the magna beat him by only 2 seconds.
the magna looks fast, but a skyline going just as fast looks sooooo much betta.
Edited by =premo=
https://www.sau.com.au/forums/topic/84158-motorkana-vids/#findComment-1527051
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
