hey
I went to a rim shop today to get a quote on the Lenso D1R rims
from previous post few pages back I was going to go with
front 18x9+32
rear 18x9.5+30
however they no longer make the 9.5's
which means id have to go with a 10inch for the rear to get flush
I'm hoping they still make the 18x10+36 as outer position like Alex said will be the same from the outside
but being a 10inch rim will it fit with no other modifications, I currently have coilovers (only wound down about 2cm all round so cars not low low just a nice height atm
also for tyre choice I'm thinking of going with ku36 245/35/18 front and 265/35/18 rear (as they don't make the 255 in the ku36)
what do you guys rkn about the tyre size choice? and if anyone can give some advice on the 10Inch rear rim would be greatly appreciated
Thanks Jason -PS I am going to go back tomorrow to find out for sure they make it in the 10+36
or what kinda work will i be lookin at to get 9 +15 on the rear....keeping in mind i dont want to run camber
yeah 265 is fairly big, but if i were to go with the 18x10+36 id need that cos dont wanna stretch the tyre and ku36 dont come in 255 unfortunatly, alternativly i can get ku31 and run 255 which should be fine aswell on a 10" rim, just thought 245 be a bit to small...
if 9.5+30 is flush wouldnt that mean the 9+15 will stick out of guards 9mm?
yeh but with natural camber of been low or some camber arms you can pull it back in its not really that much like 9mm.
245 isnt that stretched on a 10 it fits quite well actually, a 235 is fair stretched or lower.
fair point, i got a bit of natural camber atm with my coilovers just been fitted but gettin adjustable camber arms to fix that, as a daily drive i dont want camber wear on the tyres...if it wasnt a daily i wouldnt care that much.
but true 9mm isnt allot but cos i aint gonna run camber to tuck it in rules out that size rim for the rear
lets just hope they make the 10+36 which is pretty much flush hopefully it wont hit anything behind the wheel for being too wide and just wrap it in 245s or 255s , because the wheel arc is goin to sit above the wheel so dont think rolling the guards or flareing should be an issue...or will it?
not to worry went back to the rim place cant get them sizes, looks like ill just go with the 9+32 all round which should only stick in 8mm which isnt that bad its pretty much almost flush
but thanks to everyone who helped me
go the 265's.
iv got 265's on my 18x9.5's and they are only just 'flush witht he rims'. So on a 10 inch rim they will me starting to go towards stretched, let along a 245 etc.
Im actually about to throw a 275 on as a replacement this weekend. Ill let you know how that goes on a 9.5..
thanks for the reply guys but the offset for a 10inch cant get to fit my car, so im getting
front 18x9+32
rear 18x9+32
i want to get kumho ku36 they come in 235, 245 and 265 they dont make the 255
what would my better option be 245 front and 265 rear?
go for some staggered fitment.
common staggered fitment is 8s n 9's or 8.5 n 9.5
iv got the latter with 235 n 275. Loves it and the handling is epic with a little lower, little stiffer (8kg-F, 6kg-R) little camber n adjustable damper. Put the power down real nice with 225kwatw...
Just about to buy set of new Lenso D1R rims for my 32GTR
I don't like stretched tyres on rims so looking for right size rims to sit flush with guards without any part of tyres or rims poking out so thought i'd ask you guys your opinions
I can get these 2 sizes which i think would be right for a 32GTR
18x9 +15
18x10 +22
Would the 10" rims fit both front and rear on these cars without poking out?
Now in saying this i don't like the look of stretched tyres either so i would need something around 265 or bigger right?
Don't mind running staggered fitment either as long as all fits under guards
Any help appreciated as want to get it right first time
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
