Ok, so got the rb25 gearbox in. Car moves, so all is well. Get it up to speed it starts to vibrate. So back the car goes to check if the shaft is actually ballanced correctly and is straight, my mechanic went down with the car, so apparently thats fine. (apparently)
So the drivetrain people said the uni's have too much stress on them, the box needs to be raised. So, that was done, was rasied up 10mm, did bugger all to nothing (vibration moved from say 80kmh-90kmh, so an improvement).
Now my mechanic is saying it could be my diff angle. As I have those funky pineapple things, and the car being a cefiro, its most probably set up for drift.
So, now my question. Is chaning the diff angle going to help, or is the drivetrain mob trying to fob us off. Others oppinions so far is the shaft has a slight bow or bend in it. Therefore meaning even if balanced, it will still wobble. That said Id like to change the diff angle regardless.
Also what damage could I be doing by continuing to drive it?
BTW, as I forgot. Car is an 1988 cefiro, rb20det, with now an rb25det manual gearbox. One peice tailshaft like the topic says.
So any thoughts please post away.
Dave its the tail shaft hands down. either its not ballenced properly or its bent. it will eventually flog out the unis and the bearings in the front of the diff and rear of the gear box
Edited by boostn32
Yep tailshaft...maybe try and source another one to see if its any different. Or take it to another balancing mob and see what they say about it...get another opinion. The blokes your going to now might be on drugs and off with the fairies.
Well to give a quick update. We rasied the box up another 5mm today, did bugger all. However we also had the rear end up on stands, and took it up to about 100-110kmh, the tailshaft, diff, gear stick etc hardly moved, yet the left rear wheel, and not so much the right rear wheel did start to flop about a bit.
Now before you say wheel blanance, I have had two sets of wheels on the rear now, both didnt have a problem before, both now do, at the same speed. However having a 2 way diff, and no load could be playing with that a bit.
Anyway, its going on a dyno tomorrow to try and narrow it down more. We have decided to narrow it down to diff bearing, or the tailshaft.
But if anyone else has any ideas, post them up, we are all ears.
  • 3 weeks later...
if i understood what ur saying properly
why are u saying its the diff bearing if its only started since the new gearbox was put in
if so it has to be the output bearing in the gearbox or the tail shaft is not balanced properly
and dont worry about what it is doing on car stands u dont drive it there
Sorry forgot to update this.
We put the car on the dyno, tailshaft just wobbled like nothing else. So we went back to the driveshaft place. They said AND I QUOTE!!! "yeahhh it was the uni's we have had a few probs with that sort recently, so we put another type and brand on, should be ok now, bye"
I was not overly impressed, if it was for the sake of $50, I would have paid the bloody money in the first place. But its fine now 180kmh still smooth.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
