Hey guys, My line is currently having a rebuild done with all the goodies. Running a T76 and power FC. I don't trust anyone in tassie to tune the thing, just after ideas of who would be best in melb to take it to. Heard good things about ICE and Race Pace, but not sure.
Cheers, Paul.
Edited by phat_r33
https://www.sau.com.au/forums/topic/84729-powerfc-tune-in-melbourne/
They are a different art form, although Ben is a great tuner and engine builder, there are good tuners that can’t build engines and good engine builders that can’t tune :(
Ben gets my VOTE!
where is this race pace joint?
There are a few guys here that know how to build a good motor, but as far as tuning it goes, 'the best' told me I wouldn't be able to get anymore than 280rwkw with a powerFC cos they are to restrictive. And I know that to be incorrect.
Will go with race pace I think. Cheers.
i have heard nothing but good stuff about benno from race pace and have a great deal of repsect for him and the work he does. but i only take my car to paul from chasers tuning, he is the ex chief engineer of motec, so knows his tuning, good luck with ur tune tho mate.
I Live in Deer Park, and i wouldnt let anyone else tune my car!! Its worth the distance and the wait!!
hoppers crossing here....is that closer or further?
i spoze if u want it done right, an hour isnt so far to travel
ICE will probably do the job, though they are just amateurs when compared to RacePace. I don’t know how much they charge for a tune, I do know you will pay top dollar at RacePace. So if you want a quick/cheap tune ICE might be the guys to see. While RacePace are quite expensive just consider the fact that they are the best import tuners in Victoria and possibly even Australia. So you get what you pay for :(
I cannot quote exactly what Ben will charge you … I estimate;
$150 / hour
About four figures for a PowerFC tune … of course I could be wrong so ring them!
i rang up race pace just now..
$600-750 ;)
I wish i had the money to spend :D
I'll goto ice performance though I think, im sure they'll do a great job :)
ICE will probably do the job, though they are just amateurs when compared to RacePace. I don’t know how much they charge for a tune, I do know you will pay top dollar at RacePace. So if you want a quick/cheap tune ICE might be the guys to see. While RacePace are quite expensive just consider the fact that they are the best import tuners in Victoria and possibly even Australia. So you get what you pay for ;)
$150 / hour
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
