plex 15th
  • Replies 261
Barries dyno is starting to become popular again, that's good. He is a weird bloke but very good at tuning.
240rwhp is decent, shows what it can do when you get the power to the road. I've got a bit more power but can't get it down, so my times are still shit. I'll try again tommorow.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/2/#findComment-126345
Yeah, he's very down to earth, he was the first person to tune my car, knows how to fix anything which is better than most. He's always busy though which can mean a long wait to get stuff done, but still one of the best tuners around.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/2/#findComment-126373
Rhino,
Cost is $30 to drive ($25 if ANDRA member)
Opens at 5pm
Racing Starts at 6pm
Need helmet and long sleeved clothes.
Unless we get 10+ forum members together then they will assigned us a normal lane, usually 5 or 6. 10 or more then we can ask for our own lane.
See'ya
:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/2/#findComment-126455
Originally posted by RB20LagWagon
hahah, little r33 drivers dont think you ran mid 13s with stock turbo simon? thats pretty funny. Its all about the car, r33's are fatt. gotta produce power to move fat.
Watch your mouth boy :fight!:
Are you taking the boat down for a run?
I mean wagon...
Hey Skyzzer my thoughts exactly..
https://www.sau.com.au/forums/topic/8519-plex-15th/page/2/#findComment-126597
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
