Thanks to STAGE-A for the wiring
12V ------- Brown with white stripe
Ignition -------- light blue with yellow stripe
Lights -------- Red with blue stripe
Earth -------- Just use the stereo metal brackets
and heres the speaker connection wires (stagea s1 at least)
left front ---- blue (+) black with white stripe (-)
right front ---- brown (+) black with red stripe (-)
left rear ----- mint green (+) black with yellow stripe (-)
right rear ---- orange (+) black with pink stripe (-)
Useful tip guys and girls:
Always use a circuit tester as opposed to a test light, and always be very careful when doing so!
Test lights, when used incorrectly, have been known to trigger air-bags, leading to a hell of a lot of wasted cash and a big clean-up, not to mention any personal injury that may occur when a bag goes off while you're in such close proximity to the dash and/or the steering wheel.
The force and speed at which an air-bag inflates is not something you'd really want to experience first hand.
Tip if your hookin up a DVD playa as i did and want to be able to play when your driving (not just when you have the foot brake on) simply connect the hand brake wire from the deck with the earth wire from the deck and earth them both together. simple!! WARNING technically this is illegal and im not advising you to do this if your screen is in the front.
So lets get started ripping that sucker out!
Pull out the ash tray and remove the screw from behind it
Remove all your stuff from your centre console.
Stick in the screw driver here. You can also pull from the indent thing where you put things, pull up. Make sure the car is not in park, otherwise it wont come out. I just put it in N or something
Now that your console is off, unplug the ciggie lighter plugs from the back of it
Edited by AlexCim
  • Like 1
https://www.sau.com.au/forums/topic/85278-how-to-stagea-headunitstereo-removal/
Move the console off to the side, no need to unplug anything. I have extra stuff down there (hi/low boost switch)
If you have two hands, i didnt (camera) put the screw driver in the two locations. Put them pretty deep so that they get behind the vent.
The vent will just pop off once you have done that
Remove the screws that hold the stereo surround on. Also there are some clips. On my car, they were really loose and easy to pop off
It will just slide off now.
There are screws under the above the frame of the units. Make sure you remove the lower ones first. be careful not to drop any. If you do, when you remove the whole unit you will be able to grab them. Once the screws are out, the unit will drop a bit. Its fine, dont get scared.
The unit will now just drop off.
Pull it out and do what is desired
Screws for the stuff are on the side. When you remove things there are also "indents" that hold the units in. You MAY need to flex the frame a little to pull anything out (i was like wtf when i had to remove my DIN slot)
To reinstall, follow the reverse. All the screws are the same, so dont worry about mixing them up.
Good luck. I cant offer wrie diagrams as i didnt install the headunit myself, maybe someone else can post them here and ill update the post.
See the 4 way (hazard) flasher switch, top right of the picture. if you flick that out you can get your finger behind the vent and push it out, doesn't leave marks like the screwdriver can.
;) cheers :)
Do l seriously have to do all that to put an fm convertor thingy in so l can listen to australian FM stations?
if so damn.......l think l better start backing up some of my cd's, or add more songs to my Iriver.
Edited by NRGIZD
  • 3 months later...
Hey Guys,
Sorry to post here, but I'm having a bit of trouble getting the rear speakers out...Cant remove the mesh cover thingy, any suggestions? Need some help pretty quick guys. I know it has clips on it, I have already broken 2! Any help would be appreciated.
Cheers,
Chris
i've completely rewired and reinstalled all speakers/splits/tweaters and also installed a sub box in the boot, so i know how the stagea pulls apart. if anyone needs help give me a buzz
x2 here!!
even know how to get 0 guage wiring through the firewall!!
Back speaker set up is awesome ... fronts were a pain as hoped not to have to make a custom pod behind the skin, but either way came up looking good (and still stock!! )
  • 3 weeks later...
k im just installing my head unit so i'll post up the wires from the wiring harness as i go .. so far
Id advise still using a circuit tester just to ensure yours are the same as mine before you hook up your head unit, if unsure how to check just pm me.
Tip ..With these ones always use female connectors, incase the connection becomes loose the "hot" wire will always be insulated.
Ive installed my boost guage at the same time making it easy to use the same connections.
I'll post up the speaker connections as i do em ... unless anyone knows em and can post em up an save me some time too :D
Lee
k heres the speaker connection wires (stagea s1 at least)
Lee
Edited by STAGE-A
Cheers,
Nick T.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
