should i take the engine off to change it?? or just remove something that i can do it??
thanks
How do you know that the oil pump is not working?
Check that the oil pressure gauge is not the problem.
:) cheers :)
I take off the oul filter and strat engine, no engine oil out, the oil pressure gauge
show zero pressure and have red light.
take the rock cover off and start again, still no oil out..............
what should i do??
Edited by Midnight Racer
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
