Hiya sydneykid,this be my firsty ever SAU post.Just signed up.
Anywayz I have an R32 GTS4 which is currently suspended by Skippy the Bush Kangaroo on Acid.Not my choice.Was like that when I bought it a week ago.
Sooo,what I want to know is can you supply a kit to sort this evil critter out.I want everything and I want it now.What do you recommend.The car is for road use.Will be contacting GTRgeoff for one of his HICAS lock bars.I intend to do it all once and do it right before I spend all my money misbehaving.Also if you can recommend a workshop in SE Qld that would be great.
PM on its way
:P cheers :P
  • Replies 714
Posted Images
Ok, so I've finally found the right thread to post in... SOrry about this... I'll learn to read a little more before posting.
hey sk...
My JIC coilovers are rattling and looks like they need a rebuild. I need to get rid of them I think. Mackay has really shitty roads, but I like a low car. Is there a setup possible for this? I like my car at a weird height - the Front slightly lower then the back (looks meaner I think heh)
Anyway, for the moment I just want to replace the coilovers because the cash storage isn't that great at the moment. Its a 1996 GTS-T so it hasn't worn many of the parts out just yet.. (pedders checked)
What would you suggest? I attached a few pics of the car to give you some idea of the height.
The measurements at the moment are (from center of wheel to edge of guard)
Back - 335mm
Front - 320mm
Hope I'm not being a pain in the ass.
What will I need?
hey sk...
Back - 335mm
Front - 320mm
What will I need?
hey sk, are you able to help.. Sorry if I'm being pushy.
PM sent
:thumbsup: cheers :no:
PS, sorry for the delay, people who send PM's get answered first, questions in posts come second.
Edited by Sydneykid
PM sent
:laugh: cheers :woot:
thats cool.
Hey, do you have a recommended Height setup between front and back?
For example, my front and back heights are 15mm different (back is higher), could this cause issues with types of driving eg. Dragstrip, and daily driving?
Front Castor Kits. Are they adjustable or preset at 7 deg?? Will they only work with the Bilsteins or can they be used in conjunction with stock or other coilovers?
thats cool.
Gidday Mafia, this is Garys recommended settings which you can get with this kit
For the street here are my recommended settings;
Front Camber -1.00
Front Caster +7.00 (slightly more on the left to offset the drift to the gutter)
Front Toe 0.00
Rear Camber -0.5
Rear Toe 2.00 mm in on each side
For the track;
Front Camber -2.50
Front Caster +7.00 (or more if you can get it)
Front Toe 2 mm out each side
Rear Camber -1.25
As you can see the big change is camber, what most the guys do (me included) is to use the Whiteline camber kits to adjust the camber when they have the car jacked up to put the track tyres on. Just get the wheel aligner to mark the amount of rotation you need for the 2 settings. Then you simply rotate the offset bush for the right amount (track or road).
The Group Buy Bilsteins have additional circlip grooves added so you can set the height you want before you fit them. There are 6 grooves 8 mm apart and I can tell you the height that you will get from each groove. Keep in mind that GTSTs handle best around 350 mm front and 340 mm rear (centre of wheel to guard).
    • To plug the hole. The engine plant may not have known whether the car it was going into had a gauge or not. It was a long time ago and the integrations might not have been fully modern. Or they might not have cared because the extra inventory and processes to save a few cents on the sender might have cost more anyway. But please tell me you are not still confusing the idea of a pressure gauge sender, and an oil pressure light switch. The switch will be out there. In a separate hole. Probably with only one wire running to it. Running the light.
    • Blower needs to go low on the exhaust side, displacing the AC and PS, which you have to decide whether you want to keep and how and where to relocate if you do. Electric option for PS is, at least, helpful. Sadly, there is no workable 12V electric AC of any value. Whilst the blower is the last compression step before the throttle, and so it might seem a good idea to have it near the inlet manifold (as mentioned above), you probably want it to go through an intercooler first, so, having it on the opposite side of the car facilitates that air flow path. The turbo discharges into the blower, so proximity of the turbo's compressor outlet to the blower's inlet is nice. But then you might want to intercool that too, before boosting it again....which would probably be a ball ache. Routing pipes out to the front and back could be a bit shit. If there was room for (at least) a small (but preferably larger) water to air core on that side, then that would probably be the best approach. I guess a reasonable alternative would be to locate the blower where the alternator is (more or less, associated with the inlet manifold, per Matt's thought), and somehow incorporate a water to air core into the manifold, sort of like they do for modern blown V8s. The big difference here though is that those V8s have only the one throttle (upstream the blower) and only the one compression step (the blower) and no need for too much in the way of bypass/blowoff valves. Whereas in a twin charged 6, you do need to think about one or two bypass valves associated with the 2 compressors and you would prefer to have the intercooling done before the air has to pass through the throttle. You'd like the throttle to work approx the same no matter what the compression is doing. But if it is located in hot air stream before a cooler, then sometimes the air will be real hot, sometimes it will be quite cool, and the throttle mapping/response will be quite different between those two cases. The throttle, if sized for hot air, would be too large for cold conditions. It's all a ball ache.
    • Package SC on exhaust side. Remote mount turbo. Still a fair bit of room when you get creative on the inlet side of the motor too. Especially if you can get really creative with the welding, and effectively build it into the bottom of the inlet manifold. Would definitely take some design work, and some trial and error, to make sure flow works well still! Might be easier to just start with the Nissan March though... All the work is already done for you...
    • I'll sit down and get a post together 😁
    • The factory oil pressure sender is no longer in the car that's what is confusing me. In the Taarks adapter I have an aftermarket Bosch style pressure/temp sender and the factory temp sender only. Oil pressure is perfect. Where does the factory oil temp sender go to if there were never any gauges? Why was it there from the factory?
