For some time I have been getting requests from many people for my recommended suspension components and settings. So I have organised a SAU Group Buy for Whiteline suspension components and Bilstein shock absorbers for R33GTST Series 1 and Series 2. We get 15% discount off recommended retail and free freight if the individual order is over $500. Plus anyone who spends $1,000 gets an additional 5% discount.
I have chosen the springs rates and the stabiliser bar rates based on my experience with this model. Plus the shocks come with matching valving for those spring rates and 5 circlip grooves for setting the height up just how you want it. In addition the adjustable stabiliser bars come with 2 extra holes for even more adjustment.
The recommended settings for road use are also included.
Delivery is via Toll Priority and I have organised an Australia wide price, so it doesn't matter where you live, you will get the parts at the same price as everyone else.
Please pop over to the Group Buy section for full details.
;) cheers :)
PS; I did R33GTST as it is the most popular Skyline model, but if there is enough interest for other models I can organise a similar Group Buy. So please let me know the level of interest. Obviously it will take me a little while to specify all of the spring and stabiliser bar rates and the shock valving to suite.
Edited by Sydneykid
https://www.sau.com.au/forums/topic/85470-group-buy-r32-r33-gtst-suspension/
hey i have always wondered, are the bilstein shocks you buy through whiteline and the ones you are offering revalved, or are they unchanged from when they are delivered from the bilstein suppliers, and the whiteline springs have been designed with them in mind?
i ask because i asked for a set of whiteline springs and shocks from from a shop in sydney, and they said they shocks are unchanged by whiteline, so instead of buying them through whiteline then selling to me, they just get them straight from bilstein.
only odd thing i can see about my shocks is they only came with once circlip groove.
Whiteline kits for some cars don't have revalved shocks as the standard valving is OK for the spring rates. Others car, they have to be revalved as the standard valving is not OK for the springs rates, they are designed for only standard spring rates.
I have specified the valving for these as I believe that they needed changing for the springs rates. Plus I have built in enough window in the valving so that the stabiliser bar rates I have chosen are also covered. I have also specified the extra circlip grooves for the most popular ride heights.
Standard Bislteins only come with one circlip groove, sometimes 2 if the same shock is used on 2 different cars. It costs around $10 per groove extra to have them put in, for a set of 4 shocks with 4 extra grooves per shocks is around $150.
;) cheers :)
Edited by Sydneykid
Interested in full kit for a R32 GTS-4
Cheers,
R32 GTS4's can be tricky. At the bottom of the rear shocks on yours does it have the fork (like a GTR) or a bush (like a GTST)?
I have already done the valving for the R32GTR front shocks which will work very well in the GTS4, plus the spring rates and stabiliser bar rates. I haven't finished the rears yet though, but it is only a few days away.
Did you want adjustable or fixed stabiliser bars?
;) cheers :)
Edited by Sydneykid
Excuse my ignorance, I dont know too much about suspension.
Am I correct in stating that these shocks are height adjustable? What adjustment range is available. Does changing the height also change the dampening rate?
Are they easy to adjust whilst on the car?
1. Am I correct in stating that these shocks are height adjustable?
2. What adjustment range is available.
3. Does changing the height also change the dampening rate?
4. Are they easy to adjust whilst on the car?
1. Yep, they have 6 cirlip grooves, 2 higher than standard and 3 lower than standard.
2. The grooves are 8mm apart, so you get around 50 mm of height adjustment
3. No
4. No
The concept is you choose what height you want and set the circlips at that height then put them in the car. The standard circlip groove is 355 mm centre of wheel to guard, which is 25 mm lower than the new car standard with the Whiteline coils. So you can go down to 347mm, 339mm and 331mm. Or up to 363mm or 371mm. These are the most common heights found in R33GTSTs. Any lower than 331mm and you have severe geometry problems, excessive camber, radical drive shaft angles (looses HP) and there is simply not enough travel to soak up the bumps. The 371mm is close to standard for people who need the height for clearance but they want good handling at the same time.
;) cheers :)
Edited by Sydneykid
:huh: cheers  :D
hey thanks for the info, so just to get this 100% straight, if i called whiteline and bought some bilsteins and whiteline springs for my r33gtst, they would be revalved?
so the shocks i have now have different (original) valving than if the shop i bought them through got them from whiteline?
because they told me whiteline does not change the valving (i wanted a whiteline setup)
what difference does the revalving make assuming use of the whiteline springs at the original circlip height (25mm low)?
sorry about all the questions!
Edited by siksII
Sorry I don't know whether Whiteline have the R33GTST shocks revalved, they have a great shock dyno and are quite capable of specifying the correct valving for their springs. If the shock needs revalving then they would do it, if it doesn't then they won't.
I have specified the valving for the Bilsteins that I am using, based on my own shock dyno tests. Because they need to have a window that is good for the springs on their own. Plus is good for the stabiliser bar rates if someone wants both springs and bars. That's the important thing with shocks, they have a window, not one single point at which they are "right". The spring and bar rates have to fit in that window, and that's the tricky bit, particularly when you add adjustable stabiliser bars into the equation.
Height makes no difference to valving.
:) cheers ;)
ah ok thanks heaps for all the info, i just hope my standard bilsteins are in 'the window' :D
they certainly feel good! The car has excellent traction around corners, and very comfortable ride when compared with my old suspension (HKS Hypermax D (came on the car))
i would like to add bars later as well, although i can handle without, but when i do i hope the bilsteins are still in their 'window' as well!
i also always thought that valving was related to height, now i know its not...
Edited by siksII
Stagea Group Buy now completed, refer to the Stagea section for details. R32GTR and R33GTR are currently being engineered. Check the Group Buys section for their release.
:D cheers :)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
