Hey guys i need ur help
I just imported a modified R32 GTS-t that has been fitted with a aftermarket ECU (GReedy E-Manage) and I was talking to a friend who said that if I use Australian Premium Unleaded in it that the lower octane fuel may cause the engine to detonate? I believe that Japanese fuel is 110 octane where as Aussie premium is only 98 octane, would this lower octane fuel be causing damage to the engine or possibly cause it to detonate? If I used octane booster in the premium would that fix the problem until i can get the car tuned propperly for Australian fuel. I also have the link cable and program to tune the E-Manage, so if any1 has any experience using this ECU, could they tell me how to ajust the ECU to run on Australian Premium.
Thanks
Thanks
Let's start off with an EManage is not an ECU, it is a simple piggy back. The standard ECU still runs everything, the EManage smply bends a few signals (AFM voltage mostly) to trick the ECU into leaning off the A/F ratios. If you unplug the EManage the standard ECU will run the engine as per standard.
Japanese "Premium Unleaded" is 100 ron. It used to be a problem when we only had 95 ron (pre Optimax and Ultimate), we had to retune Jap (aftermarket tuned) cars all the time. But since we now have 98 ron it hasn't been anywhere near as much of a problem.
I doubt that your car with an EManage, piggy back, will have been tuned so tight that the difference between 98 ron and 100 ron is going to be an issue. I strongly suggest you have it checked on the dyno, the 20 minutes and $100 (tops) would be well worth it.
Hope that helps
:) cheers ;)
I thought jap fuel went upto 108?
check your timing. when I got my car from jap the timing was way out, and it was detonating. once I wound it back it ran fine on 98octane.
also you don't have to unplug the emanage, you could just clear the maps. with the sofware and cable, but I wouldnt recommend doing this unless you know waht you are doing and youd want to save the tune first..
so yeah best to get a pro to sort it out.
Normal pump fuel in Japan is : reg 90 ron and premium 100 ron .
You can get pump fuel at 105 ron but its very rare to find in servos .
Hey thanks for ur help fellas, ill get it tuned asap but until then ill use Bp Ultimate just incase. 1 last question, what does detonation actually sound like, does the engine knock before it detonates or does it just die in 1 hit?
The best way to describe it would be like draging a chain on the ground . It can be hard to hear in a noisy turbo car . Its easy to hear it on a stock none turbo car when under load in high gear , sometimes you can hear the car next to you when taking off at the lights uphill .
Nozila : From my experience they use 100 , i was using 90 ron an a hired mazda 2 and she was pinging !
r32's have a ping light. it's a red light on the lower left hand side of the speedo in the dash. it flashes about 3 times when the engine pings so if it ever see that indicator flash, it means u should back off immediately as the engine is pinging
u probably wont be able to hear knocking inside the car so it's best to just watch out for that light.
you could use that nulon pro strength octane booster if u're worried, but a simple tune up should be able to fix any probs
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
