  • Replies 300
Posted Images
For the guys that have ordered kits, all of the items are ready except for the springs. They are due late this week, we have had to wait for the scheduled production run at the manufacturer. Yes, "we", as I am going to stick a set in my Stagea to replace the standard springs. I already have the rest of the kit.
I am going to put the R33GTR rims (17 X 9 +30) on the Stagea and they were too close to the rear, lower spring seat for me to take any more height out of it. I could have used the (standard Bilstein rear) pressed steel lower spring seats instead of the alloy ones (standard Bilstein front). That would have let me use one extra groove (lower), but it would have not quite been enough to get the height right. So it's Whiteline spring time for me.
StageZilla, that is something you may have to look out for, depending on the offset of the wheels you are using.
:) cheers :O
Here is my order:
Stabiliser bar adjustable Front 229
Stabiliser bar adjustable Rear 229
Caster Kit 115
Rear Camber kit 128
Front Camber kit 277
Subframe lock and alignment 110
Total $1088.00
-5% = $1033.60
I'll PM Sk with details
Here is my order:
Caster Kit 115
Rear Camber kit 128
Total $1088.00
-5% = $1033.60
Actually cheaper than that Emanual, you have left the freight in. Orders over $500 are freight free. PM sent to confirm the pricing.
:) cheers :O
I thought I might post up some pictures of the standard Stagea springs versus the Whiteline coils. This is the front;
As you can see the Whiteline coils are quite bit shorter with a higher spring rate. They have to be shorter by at least 30 mm to give the lower ride height. Plus shorter again to make up for the higher spring rate, as the stronger rate holds the car up higher.
This is the rear;
As you can see the Whiteline rears have 3 coils of progressive (softer rate), these close up on installation and give a higher effective spring rate. They have to be there so that the spring remains trapped at full droop.
:D Cheers :O
PS; A few guys have asked me about the front brake hose bracket and how to hold it in place. So I have posted up some pictures in the Stagea Suspension thread.
Edited by Sydneykid
woot! sounds like its not too far away now :D
YUP - same here... as soon as I can sell my VR V8 (been advertised for soooooo long now, modified, 118000ms, 215kw, cheap as!) Im going to order some parts for the suspension, pretty much like Emanuelt's order. Im going to do half this year and half later next year! (tell you the truth, I think my shocks and springs are ACE as is!)
Brendan
wait till u see the springs commin off my car...
i dunno what they did when they did compliance.. but ive got 4 collapsed springs...... happy days almost
Really?? Wow, thats not good..........
Im really impressed with the current suspension, ie levels of handling, not too firm nor too soft, not too low nor too high, etc.
Brendan
YESSSSSSS The kits arrived today. 2 out of 2 come first then 1/2 hour later package 1/2 arrived. I will be installing them within the week. They look great quality.
As for people not sure about safty by paiding first I'll back SK 100% excewllent!!!!!!!!!!!!!!!!!!!!!!! its werth it....
I'll post some pics when I've installed the kits, hope its not too hard to do myself.
Check out the Stagea Suspension thread, I have added a few more pictures over the last couple of days as I have installed the Whiteline springs. Tried to answer a few questions people have asked me along the way.
:( cheers :)
OK I installed the rear sway bar today and have a couple of questions. I'm just not sure how much thread is ment to be exposed when i tighten things up, show in pics.
Went for a quick drive with just the rear upgraded, no body roll but now more wheel screech around corners.
Also Sk do you have any pics where the front and rear caster, camber and sub frame alignment are ment to go as I really need pics to help me out when I do them, the more detailed the better as I prefer to install them going off a pic of it already done.
Thanks very much...........
1. OK I installed the rear sway bar today and have a couple of questions.  I'm just not sure how much thread is ment to be exposed when i tighten things up, show in pics.
2. Went for a quick drive with just the rear upgraded, no body roll but now more wheel screech around corners.
3. Also  Sk do you have any pics where the front and rear caster, camber and sub frame alignment are ment to go as I really need pics to help me out when I do them, the more detailed the better as I prefer to install them going off a pic of it already done.
Suggestions follow;
1. It doesn't matter, the only thing you need to be aware of is the clearance to the exhaust system, where the bar bends in a "U" shape to clear it. If you have the links too short, the bar will hit the exhaust system on big bumps on a lowered Stagea. If you have the links to long the bar will hit the exhaust system when the rear suspension droops on normal height Stageas. From the pictures you have it pretty much central, which is OK.
2. Yep, that's what happens when you increase the antiroll. Try a few extra pounds in the tyres. The wheel alignment, via the adjustable bushes, will help of course.
3. I don't really have any pictures of installing bushes. The instructions are pretty good and once you have the parts off the car (that the bushes need to be replaced in) it is pretty obvious where they go.
The caster bushes (KCA332) go in the front of the radius rods and replace the rubber bushes that are already there.
The Front camber bushes (KCA348) go in the ends of front upper control arms and replace the rubber bushes that are already there.
Similarly the Rear camber bushes (KCA347 ) go in the ends of the rear upper control arms and replace the rubber bushes that are already there.
The rear subframe bushes go between the standard bushes and the mounts (as per the instructions). They don't replace the standard rubber bushes.
I do have some pictures of the standard components, if I get time tonight I will post them up with arrows where the bushes go.
:huh: cheers :)
Got the R33GTR wheels fitted up today with some Hankook 245/40/17's. LOOKS PHAT, well that's what I have been told. The digi camera is in Canberra today and tomorrow, as soon as it comes home I will take some pictures and post them up.
As previosuly posted I have put the Whiteline springs in with the spring seats in their standard position. It is sitting at 345 mm (centre of wheel to guard) on the front and 335 mm on the rear. That gives a 15 mm rake (nose down) towards the front, which looks purposefull.
I had the 4 X R33GTR wheels and 8 tyres in it today, plus an R33GTST gearbox and a passenger, it was very low in the rear. Since it carries loads a lot and tows the race car, I might raise it up one circlip groove (8mm) both front and rear. That will preserve the rake at 15mm, which I like.
The 245/40/17's look a little small in diameter in the guards, Stageas have big arches. So I think 245/45/17's would look better and fill the guards a bit more. I will try that sizing on the next set of tyres.
:O cheers :)
1. Front sway bar was very easy to install.  They really makes a massive difference for cornering!!!!!!!!
2. I had a look where the caster kit goes, i take it I need to take the arm off and get it pressed out and new one pressed in?
1. Yep, swaybars are the best bang for buck handling upgrade you can do.
2. Yep (again), remove the radius rod, press the standard rubber bush out and replace it with the Whiteline adjustable bush.
:) cheers :)
Could i remove the radius rod bush, and burn out the old bush?
Meaning, just cover it it turps and melt/burn it out...as i dont have access to a press..
Do i need a press to put in the whiteline bushes?
Reference : http://www.lexls.com/tutorials/suspension/fdaizenkit.html
You could burn the old rubber bushes out, oxy works great but the burning rubber smells real bad and makes a lot of thick black smoke.. The crush tube (centre) just falls out when the rubber burns. When it cools you can cut the outer shell with a hack saw. It then will pretty much fall out, maybe give it a tap with a hammer and cold chisel to help it along.
You really do need a press to put the Whiteline bushes in, they need about 5 tonnes to get them moving.
Personally I would take it along to my local machine/suspension shop and get the old bushes pressed out and the new ones pushed in. Usually $50 cash does the trick, well worth it. If you are doing other bushes, you can rent a press from your local Wrechair/Coates/National/Ace/Kennards for a similar amount. Make sure you get the right size press tools to fit the bushes.
:) cheers :)
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
