Stagea Group Buy Whiteline & Bilstein
Return flow cooler will be killing you I reckon. You can certainly push more through a low mount setup but they're good numbers for a stock looking engine bay. Mine made 345rwkw (hub) at 22psi on 98 with a "highflow" on a stock manifold but it's a long way from a normal high flow or standard engine. I used one of those Turbosmart IWG-75's and it was great with the Motec running closed loop boost with pressure being applied to both sides of the diaphragm.
Hey man do you have pic of adaptor plate by any chance I need to match up the bolt holes as my gearbox adaptor plate ones are way off the only bolts of starter motor are matching thanks
Do they always do it from the AFM? If so... You know what I'm already thinking I reckon...
The other problem is that the pan is on an exchange basis, which would be a pain to have to send original sump to Oz for the work to be done. Would ideally need to be able to pay for a locally sourced core. To that end - I'd just fabricate one outright.
