Gidday all,
I'm thinking about buying a lambia sensor and having a go (carefully) at tuning my car myself. ( have a friend who's tuned a few vl turbos etc) Just wondering if anyone can recommend any brands and know prices? I know my way around my pfc pretty well now - it can't be that hard - just time consuming but a great learning experience. Every time I get my car tuned it costs a good whack - and I'd like to check AFR's every now and again anyway.
I saw a thread sydneykid made ages ago about buying a lambia sensor and hiring it out for a week for a fee - did anything come of that?
Cheers
https://www.sau.com.au/forums/topic/85672-purchasing-a-lambia-sensor/
Its lamda :) Or more commonly known as a wideband o2 sensor.
I recommend innovate motorsports LM-1. I have one and its great. Only thing is that you have to buy it from overseas. Thing is IMO its kinda hard to isolate load points on the street for a novice tuner. Dyno is always best..
Edited by Busky2k
  • 3 weeks later...
or you could buy local from techedge
http://wbo2.com/default.htm
That's what I've done - got the 2E0 kit with bosch wide band oxygen sensor - it was the cheapest option.
I'll get it tuned professionally but it'll be a good thing to be able to check AFR's whenever I want.
Cheers
Hmm I've been quite keen to look into this, so roughly what are we looking at here for prices?
And do these sensors go into the factory O2 sensor port? I'm reading into it now but a quick short cut to the basics wouldn't be so bad? :P
If you read on the techedge website they say not to mount it too close to the turbo as they won't read right. The best place is before the cat - probably in the down pipe - that's where we'll mount it.
It wasn't as expensive as the ones from the states - all up under 400 AUD with the wide band O2 sensor although I'm not sure how good it'll be.
I use a Bosch LSM-11 sensor in conjunction with a Motec meter. The LSM-11 has been around awhile and is probably getting a bit old now in terms of the technology. Sensor itself was $500+ the last time I bought one, but that was quite awhile ago now.
http://apps.bosch.com.au/motorsport/downlo...oxygenlsm11.pdf
Wide band oxygen sensors have come down in price a lot.
http://wbo2.com/lsu/sensors.htm
I got the 0 258 007 057.
I see that motec use the 6066 which uses a bigger opening and is quicker to react but apparently can cause it to be sensitive to exhaust gas temperature fluctuations (probably most likely in a turbo application) because of this.
The 7057 was around 150AUD if I can remember correctly.
Cheers
nice info!!!
so has anyone got any concrete info on AFR's and what other people are using? like race teams etc etc?
No idea about race teams - a normal number from what I've seen is 14.7:1 for closed loop (apexi pfc) and under full load 11.9:1, although I've heard people say they lean out to 12.5:1? @ full load - guess it depends how safe you want your tune.
There's a good topic on tuning with a pfc in the stick forced induction quick reference guide at the top of this section.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
